Mercury Magnetics Output tranny
Which Mercury output tranny is good for ODS clone?
I want to build
4 6L6GC, non-HRM, non-skyliner
4 6L6GC, non-HRM, skyliner
4 6L6GC, HRM, skyliner
I found these from Mercury's web catalog.
If someone tried these, please let me know their character.
FBFTO-85 TWIN Blackface Reverb -- #125A29A
FBFTO-100 TWIN Blackface -- 100 watt -- 4, 8 & 16 ohm taps
FBFTO-100M TWIN Blackface -- 100 watt -- 4, 8 & 16 ohm taps -- smaller stack
Thank you.
						I want to build
Thank you.
				groovtubin
Re: Mercury Magnetics Output tranny
fwiw, you can`t go wrong PERIOD w/these trannies use them in my Fender HR Deluxe mods w/KILLER RESULTS, also used them in DIAZ amps when i built for them, Electric amp as well, just plain GOOD... BUT, to ME the Dual showman/bassman 100 output is well gooood...Look at Dumble SN 0124 here on forum, same output tranny. It has a really unique silky top end to it..I also use the excact same power transformer, really BIG, its dif than the twin power, and that is a VERY important thing man..tomo wrote:Which Mercury output tranny is good for ODS clone?
I want to build
Thank you.
 good luck..
 good luck..- Funkalicousgroove
Use
DO-50 for a 50 watter and use DO-100 for a 100 watter-TRUST ME!
Funk, what do those have for impedance taps on the secondary?
Funk, Thank you.
I saw Mercury's catalog, but I can't find "DO-100".
Which tranny is "DO-100"?
I'll use these tranny for Power and Choke.
Do you know better ones?
FBFTP : TWIN Blackface -- #125P34A
FBFS-C3H : Blackface -- #125C1A
Axiom OT DO-100  Dynaco -- 100 watt 300.00 227.00 197.00 165.00
http://www.mercurymagnetics.com/pages/mainframe.htm
Thank you. I found.
I checked all Brands, but I was missing the link of "Various other Guitar Amplifiers".
I got DO-100's diagram from Mercury.
secondary : 4,8,16ohm taps
primaly : ultra linear taps
Do you know better Power and choke?
Please advise.
Please advise.
Funk,
What do you recommend for the UL tabs? connect them to grids or not use them?
Thanks,
Jelle
Thanks,
Jelle
- Funkalicousgroove
Don't use the UL taps,
I REALLY like the Mercury 2.84H Tweed Bassman Choke.
Use the PT with the LOWER voltage, you really only want about 440vdc on the plates.
If you're using one of my chassis they are drilled to fit a standard Twin Reverb OT, so you may have to add a couple holes to fit the mercury.
Ok, thanks!
Will the Bassman choke also work for 100w amps?
Jelle
Jelle
				groovtubin
totally agree, the westminister i had in here w/dynaco OT sold meFunkalicousgroove wrote:Use
Hey, how are you doing! Thanks for the info!
Jelle
						Jelle
Greetings,
Check out these Dyna-clone OT's! Power transformers, too!
http://triodeelectronics.com/dytr.html
Note: A 17W rated Hi-Fi OT can do very well with 35 W rated guitar amp, while a 35W rated Hi-Fi OT can do very well with a 70W guitar amp.
Look at the prices (compared to Mercury)
All the best,
Sven
All the best,
Sven
delete me
