Which LEDs for footswitch?
I'd really like two different colors for OD & boost, and ideally I'd have a 3rd one when OD is NOT on.  For instance, clean mode=blue, OD mode=red, boost on=orange or green or something other than red & blue.  If I can only use one color then there would be no clean mode LED.  No big deal.
I've seen the chrome bezel one that Hoffman sells. Seems to only be available in red. I do like that bezel though. Does anyone know of a Mouser part that is similar?
What have you used in the footswitch?
Thanks, folks!
Thanks, folks!
Me: Just one more...
Re: Which LEDs for footswitch?
Mouser carries a XICON chassis mount chrome bezel.I've seen the chrome bezel one that Hoffman sells. Seems to only be available in red. I do like that bezel though. Does anyone know of a Mouser part that is similar?
MOUSER Part No. 351-1001 fits any T-1 3/4 size.
You may already know this, but If you want the same intensity from all leds, then pay attention to each LEDs specified Vf (forward voltage). Subtract the Vf from your voltage source, and divide by the amount of current you want the leds to run at. (15mA nominal). That will tell you what your current limiting resistor values should be for each led.
Bob,
Thanks so much! That is EXACTLY what I was hoping for.
Michael
Michael
- Funkalicousgroove
Dude, go to Radio Shack!!!   They have all kinds of colors and Bezel's, after you figure for shipping the $$ is the same.
LOL!  I haven't been in there in a LONG time.  I'll check it out.  Thanks.
				groovtubin
no doubt that`s where HAD got his before mouser came along! jpFunkalicousgroove wrote:Dude, go to Radio Shack!!! They have all kinds of colors and Bezel's, after you figure for shipping the $$ is the same.
- Funkalicousgroove
Every relay supply transformer in every Dumble amp I've ever seen has said Radio Shack on it!!!
Rad Shack Bezel
I'm a little confused about the LED issue. I figured if you wire the LED and a resistor across the footswitch that the LED would light up when the switch is open, then go out when the relay is activated.
I have a Marshall replacement 2 button footswitch. It works fine without the LED's but as soon as I connect them the relays stop working and I measure 7.9V arcoss the relay. I'm using a 12V regualtor on the supply.
What gives?
What gives?
I had the same problem with Marshall footswitches. I ended up just wiring the LED in series with the switch. Works like a charm.
Thx, I'll try that tomorrow.Normster wrote:I had the same problem with Marshall footswitches. I ended up just wiring the LED in series with the switch. Works like a charm.
