1/2 watt ok?
iknowjohnny
1/2 watt ok?
For 12AX7 plate resistors on a 300V PI?
Re: 1/2 watt ok?
If you draw 1mA = 0.001 and Rtypical is 100k...
http://www.ohmcraft.com/technicalinfo/0 ... torial.pdf
W = (0.001)^2*100000
Re: 1/2 watt ok?
I use 1/2 watt should be no problem.
The world is a better place just for your smile.
iknowjohnny
Re: 1/2 watt ok?
Thanks. I normally use 1w because the leads are much thicker, but i needed a value i didn't have in a 1w. I will replace it next time i order resistors, thanks.
Re: 1/2 watt ok?
Over rating on wattage can help to cut down on hiss.
