Rating of Ohmite Resistors in Concorde/K60?
lgehrig4
Post by lgehrig4 »
I'm talking about those 2 resistors connecting +/- from the bias jacks. The layout says 1Ohm, but I'm not sure how many watts they need to be.
Thanks!
Jeff
dave g
Re: Rating of Ohmite Resistors in Concorde/K60?
Post by dave g »
If you assume 50 mA per tube...
Power = Voltage * Current
Ohm's Law states that V = I*R, and in this case R = 1, so we've got that V = I, so power = I^2 = 0.05*0.05 = 0.0025 watts.
A 1/4 watt resistor is capable of dissipating 100 times more power than you need, so don't worry too much about it :D
lgehrig4
Post by lgehrig4 »
Thanks. Must be the reason it's the only resistor on the layout that doesn't mention the wattage
