dumb Celestion Gold question
jaysg
Post by jaysg »
I don't have one to look at....where does it tell you whether it's the 8 ohm or 15 ohm version? It's clearly not on the main label.
echuta13
Re: dumb Celestion Gold question
Post by echuta13 »
Hrmm... I have some at home, but till I get there.. Maybe like this one? [img:2981:2236]http://cdn1.gbase.com/usercontent/gear/ ... zyc_so.jpg[/img]
If you can't be a good example, then you'll just have to be a horrible warning.
jaysg
Post by jaysg »
oooo....thanks!
I would guess that the original blues were only 15 ohm back in the early 60's, so it's not on the vintage style label for the Gold.
Your meter will read about 75% of the rating. That is, ~12 Ohms for a 16 Ohm speaker, ~6 Ohms or so for an 8 Ohm, etc. It isn't perfect, but you'll know when you see the reading. If you don't feel it is too disrespectful, use a Sharpie to write the result on the speaker. I know that's what I'd do. BTW, Sharpie usually wipes off with a rag and alcohol.
