Hi all, am in the very early (parts gathering) stages of a 102 Ford type amp, only with 50W output (6L6's). Am mulling over which output TX to use. I have two at hand that I could use:
1) Late sixties Bassman head OT
2) Very nice repro plexi Marshall OT with the output taps, specified for EL34's
I noticed that the documents say that the RF 102 has a Twin OT, and it appears the pics of his amp do not show an impedance switch, yet most of the schematics show an impedance switch. IIRC a standard Twin OT only has a single 4 ohm output tap (as does my Bassman OT).
I'm a bit nervous about using the Marshall OT, am afraid it may be a bit brighter sounding than the Bassman and I don't want that. Also there may be a bit of mismatch from specified output impedance using 6L6's in place of the EL34's, but this is probably a minor concern. Finally, I will need to pull this out of an amp, and I'd rather not do that if there is a significant sonic advantage to the Bassman TX.
All you that have built 102's, any suggestions on which I should use? I have been working on tube amps for decades, and realize the impedance tap issue is not really a big deal, at least with the Fender TX's.
Finally, does anyone know what impedance RF's cab is? Maybe two 8 ohm speakers in parallel for the proper impedance for a Twin OT?
Thanks for all replies!
50w 102 (Ford) build, output TX question
Re: 50w 102 (Ford) build, output TX question
Use the Bassman iron.
TM
TM
amplifiednation
Def use the Bassman. Perfect amp for it!ToneMerc wrote:Use the Bassman iron.
TM
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
The Bassman TX wins, thanks for the replies!
Classic tone replacement transformer for bassman does a great job!MKB wrote:The Bassman TX wins, thanks for the replies!
- glasman
I love their transfomers. I use them for special one-off build etc etc.roknroll wrote:Classic tone replacement transformer for bassman does a great job!MKB wrote:The Bassman TX wins, thanks for the replies!
But my mainstream transformers come from Heyboer.
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
