Thinking about 5E3 inspired amp ...
Fender Amp Discussion
wicker
Post by wicker »
Well guys, you probably know that feeling that you must build something new (even when you don't have room for it :). Recently I've been thinking about some tweeds, first thought - 5E3 (or 5D3) inspired amp. Are there any things I should know before starting this kind of build ? I've read that the cab is a bit small and cannot accommodate all speakers (due to close chassis), I'm thinking about ordering one that is based upon this drawings:
http://thebluesalligators.narod.ru/olde ... INET_3.pdf
which is probably close to oryginal. I'm also thinking about getting a custom chassis - a little bigger compared to oryginal one - mostly because oryginal amp is really cramped. I am also wondering whether filltering caps do not suffer due to heat from power tubes that are just bellow ? As for tubes, I'll go rather into SS then tube rectifier (a bit more headroom). Last thing that stucked in my mind is a box full of EL84's that is lying in my room and waiting for use (unfortuantelly no 6*6 tubes )....
Paul
Re: Thinking about 5E3 inspired amp ...
Post by Mark »
I'd consider using a Garolite Board over the usual paper boards used for these type of amps. Should a paper board be or later become conductive you'll be pulling your hair out trying to fix the fault. Typically you'd hear scratchy volume and tone pots.
Yours Sincerely
Mark Abbott
overtone
Post by overtone »
I don't find the chassis too cramped but the depth is a problem if you use turrets which get really close to the intestines of the input jacks.
