Started on my Rocket build this weekend. Went out to visit my old man and family at the metal shop they work at, and started fabbing out some chassis. Made a few express sized chassis out of .12 inch thick aluminum, and attempted to bend and weld up a dumble chassis out of 1/8th inch thick aluminum (!) for a future build. I don't hardly ever spend much time with the old man, and to be honest it felt good to be with family and do something cool.
After I got home from all that I wired up the heaters and mounted the sockets. Everything else is ordered, with the exception of the xformers. Picked up some peruvian walnut for the cabinet - should look pretty good.
Starting my Rocket build
beasleybodyshop
Last edited by beasleybodyshop on Mon Nov 25, 2013 5:27 am, edited 1 time in total.
beasleybodyshop
Re: Starting my Rocket build
more photos
nice. i can't do it, but i like seeing home-bent chassis.
looks like you got the toughest part out of the way - wiring up 4 EL84's with the heaters wrapped around like that. what kind of wire is that - stranded or solid? i used to use solid for my heaters because i liked how they stayed in place, but my liverpool rebuild i did i used stranded and was surprised how much easier it was to wire up the heaters with it - and it seems to stay in place just fine.
beasleybodyshop
i used some teflon stranded wire for the heaters. Trying it out for the first time.kwijabo wrote:nice. i can't do it, but i like seeing home-bent chassis.
Dustin, nice job on the chassis and wiring.
I see the tray board in place.
beasleybodyshop
Yes! Out for its maiden voyageM Fowler wrote:Dustin, nice job on the chassis and wiring.
beasleybodyshop
Cut up all my walnut for the cabinet. You can never have too many clamps
Nice job!
BIG Dave: '63 Princeton, '67 SFDR, '68 Marshall 4x12, '71 Marshall JMP50, etc...
