I'm building up the power amp stage of and AC-30 clone. The first hurdle I've encountered is finding the 9 lug terminal strip. I did buy some from 9 lug terminal strip from eBay but it isn't the right size.
I'd rather try and find the right stuff before looking at other options.
Thanks for you assistance.
Where to buy 9 lug terminal strip?
Yours Sincerely
Mark Abbott
Mark Abbott
Re: Where to buy 9 lug terminal strip?
There is a 9-lug tagstrip available from Altronics: http://www.altronics.com.au/index.asp?a ... m&id=P2309
Thanks for the tip. I also found Oztraders on eBay also sell his item.
I bought a few of them as they will only get harder to find.
Yours Sincerely
Mark Abbott
Mark Abbott
I use two 5 or a 5 and a 6 soldered together and reinforced at the solder joint with soild 18 ga wire.
Little late on this and no nine lugs but some options, and you can nip them to size to. Plus my drill-out & pop rivet solution:
http://uk.rs-online.com/web/p/barrier-s ... 435796|cav
http://www.hificollective.co.uk/catalog ... -8471.html
http://www.hificollective.co.uk/catalog ... -8591.html
http://www.partsconnexion.com/terminal_ ... urret.html
http://www.tubesandmore.com/products/P-TS12-1
http://www.tubesandmore.com/products/P-HTUR-STRIP-23
http://www.tubesandmore.com/products/P-HTUR-STRIP-11
Mark, late to the party, but for future builds have a look at Evatco in QLD. They have all tag strip sizes but lately I've been using the long 28 lug strip and cutting to suit. It's made of the high quality dark phenolic material, not the lighter stuff like you'll find at Jaycar etc.Mark wrote:I'm building up the power amp stage of and AC-30 clone. The first hurdle I've encountered is finding the 9 lug terminal strip. I did buy some from 9 lug terminal strip from eBay but it isn't the right size.
http://evatco.com.au/product-category/t ... s-turrets/
I've also used Ampmaker in the UK. Freight to AUS is much better than the US based stores.
