New 2204'ish Build
Marshall Amp Discussion
jeff12
New 2204'ish Build
Post by jeff12 »
Here is my new 2204'ish build using transformers I had laying around.
Checking voltages now, should have it up and running soon.
If all works out well I will most likely add some mods to it.
Want to hear it first as is. Never used Mojo Dijon caps before, hope I like them. :) Used a smaller than standard chassis for this model amp and aluminum. I want to put it in a small box Marshall style cabinet. More than likely will have to a make faceplate for this amp. Have to get Marshall style knobs yet too, may not sound right with Fender style knobs. :lol:
NickC
Re: New 2204'ish Build
Post by NickC »
Looks great. Very neat and tidy. 8)
Blackburn
Post by Blackburn »
Great lookin build! :)
overtone
Post by overtone »
good work there, I actually like the F-style knobs on the raw chassis too.
jeff12
Post by jeff12 »
All up and running after a few minor tweaks. Output transformer leads were backwards :shock: OUCH. Also a minor preamp wiring issue. :oops:
Now it's time to try a few mods.
Looks great, buddy!
Very nice looking amp.
sepulchre
Post by sepulchre »
Looks Clean. Nice work!
dcribbs1412
Post by dcribbs1412 »
Congrats jeff12
nice build...have you used those PEC pots before...
Wondering if there is a noticeable difference?
Darin
jeff12
Post by jeff12 »
dcribbs1412 wrote:Congrats jeff12
Darin
I like the PEC's for volume and tone, not so good as a replacement in a VVR circuit. Nice taper and feel. I use them on almost everything I build now.
Ground buss has to be wired different because you can't solder to them but that is an easy fix.
sepulchre
Post by sepulchre »
I don't think you need to solder to the bodies anyway. I've heard a LOT of opinions I respect that say it's not a good idea. But, that's just me.
lumox0013
sweet
Post by lumox0013 »
Nice build!! I like the pecs where did you order them from? what mods are you planning?
Live , Love , Learn
jeff12
Re: sweet
Post by jeff12 »
lumox0013 wrote:Nice build!! I like the pecs where did you order them from? what mods are you planning?
Thanks, got the PEC's from CE Distribution, have to have an account with them but you can also get them from Antique Electronic Supply. That is their retail outlet. Not sure just what mods to do yet. Like the amp through 65 watt Celestions in a 4x12 better than Vintage 30's. 4x12. Still working on what it sounds like stock with different tubes and speakers before I decide what mods are needed if any. :D
Lummox
Post by Lummox »
That's a really tight, nice looking build. Are those Belton tube sockets ?
jeff12
Post by jeff12 »
Lummox wrote:That's a really tight, nice looking build. Are those Belton tube sockets ?
Thanks, yes I like the Belton sockets, I use them in all my builds. :)
