Just completed a a zwreck build, having current draw issues. I used a two el84 output stage, gz34 rectifier. Power tranny is a from a hammond ao43 this is the fourth wreck style build I have completed using this setup all the others work flawlessly. Power supply is as follows
from rectifier to stby, stby to 250ohm resistor and 40mfd cap and bplus 1
output side of resistor supplying bplus 2 then dropping string paralleled to b plus 3,4,5. of bplus 2 node
I have low bplus 1 only 100v. The amp sounds wicked good, less this little current draw issue, any thoughts
z wreck build power supply issue
Re: z wreck build power supply issue
Funky PT or rectifier perhaps?
What are you seeing for voltages on the PT primary and at all the used pins of the GZ34?
Dave O.
Dave O.
