hi,
how can i mod a dr z brake lite to reach lower bedroom level?
thanks for a tip.
cheers
How to mod a Dr ZBrake Lite
vibratoking
Re: How to mod a Dr ZBrake Lite
Take a look at the original Airbrake design in the Trainwreck files section.
thanks for responding.vibratoking wrote:Take a look at the original Airbrake design in the Trainwreck files section.
do you have the url perhaps?
cheers
thanks lot.NickC wrote:https://tubeamparchive.com/viewtopic.php?t=8733
i think it would work just to add a 25 ohm /20 watt resistance in serie to the 25 ohm resistance between switch position 4 (bedroom).
this would raise the 25 ohm original to 50 ohm in position 4.
this should lower the -11 dB original to about -20 dB,
(i hope)
cheers
ps
may be even a 10 watt resistor would work in this position.
and it should be enough place for it.
