Or maybe a good theory plan for a chain of pedal/rackmount that's works for you???
My pre-amp footswitches and pedals before Fender amps
and "not in any particular order" are:
* Peavey RockMaster Preamp
* DeArmond 1602 Volume Pedal (passive)
* Dunlop Crybaby WahWah
* BKButler Original Tube Works RT-4001 active DI Direct Input Box
* Stomp Boxes = MXR M-164 OVERDRIVE (+) Reverb, Delay, Echo, Chorus, Boost
* KORG DTR 1000 Rackmount Digital Tuner
Question: Does it really matter if the Korg Tuner is first (or last) in line from the guitar? or can
the Korg Tuner be added anywhere that's convenient “before or after” another rackmount effect?
I’m thinking of the following effects order. Please be free to tell me how bad my order is or make corrections,
so I’ll better understand reasoning for good or bad guitar signal paths towards a Fender amp.
Thank you for being “pleasingly BRUTALLY honest" with your kind comments
screwing around with the effects, but really would love to know who likes what and why?
. . . . and who wants to avoid a signal disaster and why?
1) Guitar out to Butler Tube Works RT-4001 DI Box * Hopefully, the RT-4011
will clean up “bad crud signals” picked up from the guitar’s
cable’s high-impedance load. Now, with a clean guitar signal . . . .
2) Butler Tube Works RT-4001 Box to passive DeArmond 1602 Volume analog pedal
3) Passive DeArmond 1602 Volume pedal to a pedalboard of desired stompboxes:
a) MXR M-164 Distortion, b) Reverb, c) Echo, d) Delay, e)Chorus, f) Boost
~ that’s it for the stomp-box type pedals
4) Stompbox pedals out to the Dunlop Crybaby WahWah
5) Crybaby WahWah to the Peavey Rockmaster Preamp
6) Peavey Rockmaster Preamp to a Fender amp’s clean channel.
Does this order work for you? Make sense? Some effects in wrong order? PLMK.
WHERE WOULD YOU PUT the rackmount Korg Tuner within the above lineup?
Thanks for your help and comments.
All items will fully arrive within a week (I hope).
Toppscore
