SE Rocket
SE Rocket
I am building a SE amp with the first two preamp tubes and their components for a Rocket. The power section is from the Jones Amp 3 Tube SE Wreck using one 6v6. The Rocket layout has the signal going from the center of the treble control to a 220k then a .047 before it hits pin#7 of the PI (which I won't be using). Should there be anything between the treble pot and the 2k2 that is attached to pin# 5 of the 6v6? Any suggestions would be appreciated!
se rocket
Hello! Off of pin#8 on the 6v6 there is a 22uf/ 470ohm going to ground. The Jones Amp schematic is on the SOPHT AMPS .com website . He designed the Derailment from the Jones Amp. Thanks for the FAST HELP! Andrew In Alabama your logos' name is "Ready Kilowatt" for Alabama Power Co.
Re: SE Rocket
Hi Andrew,
here is what should be done:
0.047uF (from the treble pot) -> 470k to ground -> 2.2k to pin 6 of the 6v6
That's it! You can also add a 1M audio pot between the 0.047uF and the 470k for a master volume.
BTW, I didn't design the Derailment, I simply build one with a few mods.
Stephane.
Stephane.
Re: SE Rocket
Hi Andrew,
yes, you would need to adjust at least the preamp b+. Which power supply are you going to use for your SE Rocket?
You are going to use a 6V6? If you are going to use a 6V6, that power supply might be to big for it. A 6V6 has a max voltage of 350V. A 325-0-325 power supply will put out about 450V once rectified! The 250-0-250 transformer is dead on for a 6V6 (about 350V rectified). I say stay with the 270CAX if you are going to use a 6V6.
Stephane.
Stephane.
Re: SE Rocket
Yes sir!slajeune wrote:A 6V6 has a max voltage of 350V. A 325-0-325 power supply will put out about 450V once rectified!
My first DIY guitar amp was a champ (5E1) using iron from A.E.S. I ended up using a big WW resistor to drop the B+. I wouldn't go higher than 300 VDC on the 6V6. I say this because I tried a Big Muff with the amp and fried the 6V6 by turning the level (on the Big Muff) up too high. I have since limited the max output level of the Big Muff.
I've been thinking of building a SE or PP amp with 6N1Ps.
SE Rocket
How about OT transformers? I'm using a Hammond 125CSE single ended 8watt with my 270CAX. Would a 15 watt sound "better" ? Also, is it possible simulate the sound of the heavy driven PI in a SE amp? I am using the Rocket preamp layout using half of the first tube then the full second tube then the power section of the Adams Amp. Pin#1 of the half tube to B+4 --Pin#6 of the full tube to B+3 -- Pin 4 6v6 1k2w to B+2 --- OT trans to B+1 Thanks for all the help guys! Andrew
