liver pool gain too hot
harris51
Post by harris51 »
any suggestions on how to tame the gain barely cracked it want to explode.
funkmeblue
Re: liver pool gain too hot
Post by funkmeblue »
what is yor rc combo going into v2?
harris51
liver pool
Post by harris51 »
68k going to pin2, 10k going to pin3
funkmeblue
these are high gain amplifiers ....think as the volume as a gain control and use your guitars volume to control the beast
funkmeblue
you could add a fast gradual switch
geetarpicker
Post by geetarpicker »
Yes you need to back the guitar down with an Express or Liverpool for cleans. Reducing the gain with 12AU7 and or 12AT7 is another easy option however the amp's overall EQ will also be altered and the singing gain will be compromised. Check out my Youtube video "Trainwreck amp tech talk" for more detail on working with such high gain from the guitar knobs. Also check the volume pot in the amp to see what taper you have as all audio tapers are not the same. On my '85 Express the 1meg volume pot is at a mere 100k at half rotation. This is one of the details that make a wreck more user friendly. Same goes for the pots in the guitar, as pots with a gradual taper are very important especially when paired with these amps. If all else fails build a Rocket and go with pedals to boost it for leads.
sliberty
Post by sliberty »
funkmeblue wrote:you could add a fast gradual switch
+1
Also known as a split plate load resistor, this is a great way to turn a beast into an amp you may prefer. And it can be tuned to your liking by shifting the balance of he resistors too.
I also love 12AT7's in my Express, so I imagine they will work well in a Pool too. Try them in V3 and/or V1.
harris51
liver pool
Post by harris51 »
will a 33k resistor help on the shielded input jack run instead of the 15 k
harris51
liver
Post by harris51 »
actually the guitar volume is off and when I crack the gain on the amp even a hair it's like it's dimed :shock:
sliberty
Re: liver
Post by sliberty »
harris51 wrote:actually the guitar volume is off and when I crack the gain on the amp even a hair it's like it's dimed :shock:
If you are getting sound (and lots of it) when your guitar volume is off, something is wrong with the guitar pot or wiring.
harris51
liver pool
Post by harris51 »
I using a 1 meg 53c3 clarostat 105a if that helps anybody know of a better one?
harris51
liver
Post by harris51 »
even when a guitar is not plugged in crack the gain and it's dimed
sliberty
Post by sliberty »
I apologize if this sounds harsh, I don't mean it that way. But unless you can be more descriptive, noone will be able to help you.
If you don't have a guitar plugged in, and you turn the amp up, you would have no way of knowing how gainy or distorted the amp is. All you would know is how noisy it is. Maybe that is what you are actually asking about? Noise?
Please tell us EXACTLY what you are doing, and what you are hearing, and what bothers you about it.
harris51
liver
Post by harris51 »
I guess what I ve been trying to say is with or without the guitar plugged in, you crack the gain on the amp and it sounds like its gonna explode ( noise,)
sliberty
Post by sliberty »
OK, now we are getting somewhere :)
We thought you were saying that the amount of gain and distortion was more than you liked when you played through the amp. So ignore all previous answers.
Now, let's talk about noise.
Is there a lot of hum, or hiss, or both?
When you say "without your guitar plugged in", do you mean that there is no cable attached to the input jack on the amp, or is the cable connected to the amp, but just not to the guitar on the other end?
