Changing caps to get a more transparent, sparkly, rich CLEAN
Joost
- Location: The Netherlands or Holland. Whichever you prefer
After playing my amp for a year now, I am in the mood to do some more experimentation. I'm still really excited about the amp and its qualities. Even though this amp has a built-in buffered Dumbleator and master volume, it gets quite close to my benchmark clean tone.
My benchmark clean tone is the Carr Rambler. For those of you who don't know that one, it's a non-master volume single channel clean amp based on an old Fender 6L6 design.
Now, I want to experiment with my clean channel on my 124 to get even closer to the Carr clean sound. And yes, I know there are vast differences in the layout and design.
I was thinking of experimenting with caps first. Which capacitors should I use to get closer to that kind of clean tone?
Mullard Mustard? Mallory 150s (which is what Carr uses)? Certain SoZo caps?
Or do I need to change my power board to all Solen fast recovery caps like Carr does in all his amps?
Who can help?
Who can help?
diagrammatiks
Re: Changing caps to get a more transparent, sparkly, rich CLEAN
ya all film in the power supply is the first step.
Joost: maybe make the skyliner tonestack more towards a classic tonestack?
Joost
Well, I don't know if that's the solution. You see, I like the basic 'voice' of the amp, I just want it a bit more transparent and harmonically rich. The Carr just has a richer/clearer sound. I figured that could be addressed by tone caps or power supply capserwin_ve wrote:Joost: maybe make the skyliner tonestack more towards a classic tonestack?
Maybe we can try some things tommorow? edit; sry friday!Joost wrote:Well, I don't know if that's the solution. You see, I like the basic 'voice' of the amp, I just want it a bit more transparent and harmonically rich. The Carr just has a richer/clearer sound. I figured that could be addressed by tone caps or power supply capserwin_ve wrote:Joost: maybe make the skyliner tonestack more towards a classic tonestack?
I have some ideas about this.
The power supply; voltages and things like totem pole arrangement of the filter caps have both influence on feel and sound. Not a fast take to try
marketing...diagrammatiks wrote:ya all film in the power supply is the first step.
expensive components won't make your amp sound the way you want, focus on design instead
consider also that ODS cascades clean into OD, change clean sound and OD will be affected too and not in a pleasant way...
is your treble cap a ceramic one? I suggest you start from here and change with a not so expensive silver-mica
than consider if you like the direction your amp has taken
cheers
teo
I gotta say that I played somebody's D'Lite that they converted to Solens and now I know what it means when somebody calls them fast.
The amp felt real stiff, no life in it at all.
Some may like that in a high gain metal amp but for rock/ blues I didn't care for it.
But you know what?
You will never know how something feels or sounds unless you experience it.
But you know what?
noworrybeefcurry
Just my input, but I always felt that a big part of the ramblers sound was the fact that both 6l6s are running in class A. Also I don't believe that it is using a standard long tail Phase inverter, I think it is something closer to a 5e3 style phase inverter
diagrammatiks
marketing?llemtt wrote:marketing...diagrammatiks wrote:ya all film in the power supply is the first step.
Are you for real?
Are you seriously saying that the difference between film caps and electrolytic caps is marketing?
Seriously? Do you understand science?
"Seriously? Do you understand science?"
2 ambigious words here: Understand and Science. Can you be a little more specific?
dcribbs1412
You mean changing the sequence of the first filter caps?erwin_ve wrote: things like totem pole arrangement of the filter caps have both influence on feel and sound.
Darin
hi Darin, the b1 is already totem pole, but modern dumble designs have all filter nodes in totem pole. It feels faster.dcribbs1412 wrote:You mean changing the sequence of the first filter caps?erwin_ve wrote: things like totem pole arrangement of the filter caps have both influence on feel and sound.
Darin
dcribbs1412
Thanks erwinerwin_ve wrote:hi Darin, the b1 is already totem pole, but modern dumble designs have all filter nodes in totem pole. It feels faster.dcribbs1412 wrote:You mean changing the sequence of the first filter caps?erwin_ve wrote: things like totem pole arrangement of the filter caps have both influence on feel and sound.
Darin
If understand correctly...this would be what some call the precision power supply.
diagrammatiks
You really need me to explain the differences between aluminum electrolytic capacitors and film?BobW wrote:"Seriously? Do you understand science?"
This seems like something you could easily try out for yourself.
