amp makes a pop when I turn it off!
				gary sanders
WTH? Maybe need a cap across switch or something?
						Re: amp makes a pop when I turn it off!
what model of amp?
PCB?
often times it's an arching PCB the voltage looks for the shortest path to ground.
does the amp still have a death cap?
when was the last time the amp had a cap job.
it can also be tube related.
or a failing switch.
If it's a marshall JCM2000 throw it away.
									PCB?
My Daughter Build Stone Henge
Hey I just finished my first build and it does a similar thing when I turn the
power switch to off position, it makes a thump sound with a slight whistle in the speaker.
I would like to know what causes it, I guess it could be a switching transient
when the switch is opened.
