Fender Super cabinet blueprints?
GCBluesman
Post by GCBluesman »
Hi everyone, I have a 60's Super Amp cabinet that I cut down Like a dummy
when I was a teenager, to make it look like a bandmaster.
Now many years later, I did a cap job on it and replaced all the tubes, It sounds good, except for random crackling, Gets quite load then moving the 6l6 tube it goes away, maybe tube socket problem?
Anyway, I want to rebuild the cabinet back to the way it was before I destroyed the value. I have still have the top of the cabinet, but will need to build new and add the 2 ten inch speakers.
Does anyone know where I can get some dimensions for the height, Side panels, top with the 25 degree slope is about 8 3/4 and bottom that I used is 9 1/2. So it then tapers. But not sure on this. I f I can get the height I should be able to figure out the rest of the dimensions, Also not sure which size speakers this had? Any help would be appreciated
GC
Sigala
Jack Hester
Re: Fender Super cabinet blueprints?
Post by Jack Hester »
Send me an email reminder (email listed in my profile), and I'll check this evening. I have some Fender cab drawings, but don't know if I have the one that you need.
Jack
billyz
Post by billyz »
GCBluesman
Jack thanks Jack, hope you have it
and BillyZ! Yes that is it Now I hope I can get some detailed dimensions!
Thanks Y'all
GC :wink:
Sigala
