Anyone do a Liverpool with Heyboers Lately???
Yea,Im wiring the heyboers HTS 5199 and the HTS9633.Got a few guestions on conections looking for someone I can go over them with.Thanx Mikey
Re: Anyone do a Liverpool with Heyboers Lately???
Hello Mikey.
Let us know about your questions.
Hey
Hey Mark I pm"d ya Bro,Mikey
Trannies
Thanks Mark,Im good on the power transformer,also on the impedence.
How about the Output,Ive got Purple,Green,Blue Center Tap.I assume the blue is going to ground and the other 2 go to the power tubes just not sure which one goes where??Thanx Brother,Mikey
EDIT This is not correct the wire goes to the standby switch as Taylor noted below.Blue on primary side (the Center Tap) goes to ground yes, with your PT Center Tap.
Green primary side to one set of EL84s and the purple to the second set of EL84s. Keep them longer so if you have to switch the leads from side to side you can.
Common on secondary side to output jack grounding tab.
amplifiednation
I thought the CT on the primary OT went to the standby switch?
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
OT center wire certainly would not go to ground it goes to the standby switch.
I apologize Mikey, nice talking to you yesterday take care brother.
I sent Mikey an email as well I know he has not fired the amp up yet so I didn't ruin his amp with my misguided effort.
Liverpool
Heres some pics.I would like to try the Lar/mar master.Mark,where should I pull the master vol off the board?Thanx Bro,Mikey
Thanx
Oh,Almost forgot to mention I got everything from rj.Really nice stuff and as always really organized nicely & ready to go.This will complete my Trainwreck builds.Rocket and Express work great,very quiet.The rocket vs express is a world apart in the tone department.Im anxiose to play the Liverpool.I work slow and try to savor the build,Its half the fun.Before you know it they are done and your jonesing for the next one.I might try a JTM 45 next.Im thinking about trying to add reverb in.The Metro foremn still has the build guides.I dont think you can get the whole kit anymore so I would source parts.Oh well.Thanx guys,Let me know if you see anything wrong,I know the board is missing a 47pf and a .0022 orange drop,Thanks Mikey
Mikey I am attaching the diagram for connecting the Lar-Mar PPIMV
2 conducter shielded
Hey Guys,I ordered some parts to do the Lar/Mar.This cable from mojo seems really tiny.Is this the corect stuff?.The ground thread is like THREAD!
I was expecting regular shielded just with 2 wires and a ground but not that thin.Thanx Mikey
OK
OK Mikey Ill get this one,You didnt read the small print that is on the Lar/Mar
parts list .It said 22 GUAGE 2 conducter shelded cable
YOU gotta read the small print!
Ok
Well today Im going to fire up my Liverpool.I decided no master yet.Just want to hear the true liverpool sound first.Cant wait!!!Mikey
Hi,
I miss your cathode of the inner two tubes! Pin 3 of V5 and V6.
Did you hook them to the heather? it looks like. Hope not.
Hans-Jörg
Hans-Jörg
Thanks Man,Better pics,Wifes home from work today ,no amp fun
