 2 questions
1) Do you think its possible to accurately replicate the sound?
2) What circuit do you guys think is the holy grail of Vibroluxs 5E11, 5F11, etc.
Any advises would also be welcome.
Thx.
 I've tried a blackface reverb and like it very much. I understand they have 6L6's so i must like the sound of them. Both amps i've built they are all EL34's (actually E34L's).Firestorm wrote:Turbo5speed -- If you have access to the right components, you can replicate the sound of almost anything if you are willing to spend the time tweaking. OT, speakers and tubes are critical. Mercury probably has clones of any Vibrolux OT you're interested in; speakers are a little dicier since you'll need to buy an original P10R (or whatever) to really nail it, but it might sound better with a different speaker; Tweed Vibroluxes are especially sensitive to output tubes -- you'll want really nice 6V6s, like VT107As.
As to what to build, that depends mostly on what kind of output tubes you prefer: 5E11 and 5F11 are nearly identical and use 6V6s. These sound somewhat underpowered IMO. You can help that a little by adding a 1M grid resistor to the input which the originals don't have. Bias should be made adjustable, too.
The 6G11s have 6L6s with the Brown era tapped-treble tone stack and the Tweed/Brown 12AX7 PI. Blackface Vibroluxes are just Deluxes with 6L6s. If you build something from that era, go with the Princeton Reverb circuit.
The Princetons have no screen limiting resistors, add at least 470.turbo5speed wrote:I was looking at the aa964 schematic and it has the Princeton reverb circuit right? I believe i am going for that one when the time comes.
Anymore input on this subject?
Thx for the tip.rdjones wrote:The Princetons have no screen limiting resistors, add at least 470.turbo5speed wrote:I was looking at the aa964 schematic and it has the Princeton reverb circuit right? I believe i am going for that one when the time comes.
rd
I've got these. Never used. Should be about 15 or 20 years old i guess. Should do the trick?David Root wrote:Some years ago I built a 6G11A with a BF reverb circuit. I added a few other non standard items like PAB on the FSW and more interstage gain control. With a pair of used RCA 6L6GCs it sounds great. Speaker is a 12" Tone Tubby Alnico, but an old P12N would be more authentic especially with those tubes, that should nail it.
