Help - need suggestions for parts for TR Ruby clone...
Forgive me if its already posted somewhere here, but I need to find a source for the rotary three way switch used on the back of my Ruby build to switch impedences from 4 to 8 to 16.  I also need the "bias test point" part, a good source for Alpha pots and Switchcraft jacks, and some help tracking down the original source of the knobs used on the Ruby.  Any help appreciated.
									Let that boy boogie woogie.
						Re: Help - need suggestions for parts for TR Ruby clone...
I think I just found the knobs - I guess they're the same as the 'Wreck knobs in a previous post from Small Bear electronics.
You can get  most of these from Mouser:
Electroswitch 3 position rotary switch, 690-C5P0304N-A
Johnson Meter Tip Jack Black, 530-105-0803-1
Johnson Meter Tip Jack Red, 530-105-0802-1
Alpha pots, either linear or audio
Thanks!  I love this forum!
  I love this forum!
									 I love this forum!
  I love this forum!Let that boy boogie woogie.
I just ordered the Electroswitch 690-C4D0112N-A and it took quite a jump in price last month from $9.80 to 15.32.
UR12 wrote:I just ordered the Electroswitch 690-C4D0112N-A and it took quite a jump in price last month from $9.80 to 15.32.
 Mouser shows it at $6.19.
 Mouser shows it at $6.19.Re: Help - need suggestions for parts for TR Ruby clone...
Different switches. I use pt# 690-C4D0112N-A and the one Elcabong posted was 690-C5P0304N-A. The one I used is a 1 pole 12pos that can be set for 3pos. The one Elcabong posted is a 4 pos 3 pole switch. Both will work but I believe the one Ken used was the C4D0112N-A. I wonder how much the other one went up. Both are still showing the lower prices and I was informed that the online catalog hasn't been updated with the new prices yet.Normster wrote:UR12 wrote:I just ordered the Electroswitch 690-C4D0112N-A and it took quite a jump in price last month from $9.80 to 15.32.Mouser shows it at $6.19.
I also had a price jump on something else at Mouser last month; catalog and on-line were out of synch.  Only true way to tell the price is to go online.
Thanks for the help guys.  I think I've got it all together now except I can't seem to track down the right pot for the bias trim pot.  In the Ruby the pot is an Alpha marked B25K 1J and has the usual screwdriver adjustment tip.  I can't seem to find it from Mouser.
Hope no one minds me bumping this to see if I can get a response.  I still can't seem to find the Alpha screwdriver-turn 25K carbon bias pot like Two Rock used in the Ruby.  Mouser has lots of other Alpha pots, but I can't find that one.  I have thought of going ahead with the upgrade to the Bourns or Claro as per other previous discussions about bias pots (and as in the Komets), but they're a LOT more expensive, and I figure if Two Rock and Fender were okay with it I probably am too.  I think this is the last thing I have left to track down, so please help if possible.
Mojo, I can get you a clarostat screw driver 2w precision pot for about $6.00. I also have the real TW knobs. Old stock for $2.50 and new stock for $1.50 I'll check to see if I have stock. You can also use a regular 2W Clarostat and mount it on the chassis.mojo wrote:Hope no one minds me bumping this to see if I can get a response. I still can't seem to find the Alpha screwdriver-turn 25K carbon bias pot like Two Rock used in the Ruby. Mouser has lots of other Alpha pots, but I can't find that one. I have thought of going ahead with the upgrade to the Bourns or Claro as per other previous discussions about bias pots (and as in the Komets), but they're a LOT more expensive, and I figure if Two Rock and Fender were okay with it I probably am too. I think this is the last thing I have left to track down, so please help if possible.
Allyn
Thanks, that looks perfect.  I sent you a PM - I tried to order from your site and ran into some trouble.  Its nice to know about your website if I need something else.
