turning cradle
				cornel moldovan
turning cradle
Hi there...Easter Rabbit wants to  bring  you  the new  Q&E  new  amp cradles, designed to  help you  work faster and easier, suitable for all chassis sizes from standard, to longer ones  as  steel string singer, or reverb  and dumbelator  equiped ones .Waiting for opinions..TURNING AMP CRADLE.also a new  proposal, a  custom made, external  overdrive including AB swiching between a zen and a hohee overdrives.. Details on mail..
						Re: turning cradle
Should be in the for sale section with a price given for each item.
Re: turning cradle
Not to be a kill joy.  Is the rotating base removable?
I tried my amp cradle on a lazy susan until I realised it takes a very large work area (kitchen table) to be able to freely spin it and not have to lift and reposition when working on a large chassis. It wasn't pratical for daily use.
My other issue was it would want to spin.
Does the base have detents or locking stops to prevent it from rotating in the event of a weight shift or an uneven surface?
My Daughter Build Stone Henge
						Re: turning cradle
I'm more interested in that chassis ODS with fender slide switch holes where did you get that?
Re: turning cradle
And tubes up, too....M Fowler wrote:I'm more interested in that chassis ODS with fender slide switch holes where did you get that?
