124 low plate classic
Attached is now a low plate Classic layout modified from the 124 layout.. AFAIK this was 124 as it was originally manufactured in 1984 before the skyline update..
To avoid any confusion on the pot tapers I labeled them by part number.. Since the Fender (CTS) were different tapers (10%-30% and the 2-35) According to my notes the 2-35 imples 2%-taper at 10%-rotation..(You must have the standard pot at "8" on a Fender knob to egual "5-6" on this pot)
For those looking for the Farris, Talk To Your Daughter, Carlos Rios type tones should look into this type Low Plate Classic..
(Posted By Max)
These four video clips are IMO a useful demonstration of some of the tones of the clean and OD channel of this 4th generation "classic” ODS circuit- including demonstrations of the way the "bright" and "deep" switches and the "rock/PB/jazz" switch influence its tone. And they give an impression of the FET tone, too:
http://www.youtube.com/watch?v=34Y3lHpKXWY
http://www.youtube.com/watch?v=SNSAj6AzWGo
http://www.youtube.com/watch?v=-qvMwCte8TE
http://www.youtube.com/watch?v=pGPxrt7d6xk
Larry Carlton with a 4th generation "classic" ODS 100W:
https://tubeamparchive.com/viewtopic.ph ... 685#137685
Here you find clips of all the ODS generations from David Lindley's 1st generation ODS up to the skyline-HRM amps in the #200+ range: https://tubeamparchive.com/viewtopic.ph ... 06&start=0
124 Low Plate Classic
