FET: alternative values
ToneMerc
Post by ToneMerc »
Anyone using values other than a 100pf capacitor and 3.3M resistor?
TM
UltraHookedOnPhonix
Re: FET: alternative values
Post by UltraHookedOnPhonix »
ToneMerc wrote:Anyone using values other than a 100pf capacitor and 3.3M resistor?
TM
I did a stand-alone FET circuit where I used a rotary switch to switch the input impedance. More info here:
https://tubeamparchive.com/viewtopic.ph ... hlight=fet
Lowering the 3.3M resistor can tame the significant treble increase to a more flat frequency response. Believe it or not, a 68K input resistor will provide that for you and anything over 100K will get progressively brighter than the bypassed signal.
ChrisM
Post by ChrisM »
You mean 3.3M/100pF or 1M/100pF? Cause the 1M/100pF filter is the tone shaping at the beginning of the circuit.
ToneMerc
Post by ToneMerc »
My reference was to the 3.3M and 100pf, while leaving everything else the same.
TM
Which schematic for the FET input is the acknowledged correct one?
Is it this #124 1988 one?
David Root
Post by David Root »
That's the one I've always seen.
However, instead of 8K2 and 8K2 I had to use 22K below the 150K entrance, and 2K5 off the FET in order to get about 10V/20V in my 100W #124, and also in my '70s ODS 50W.
David Root
Double post.
