Smoothing caps?
Smoothing caps?
I saw this in a D'Lite schematic in the overdrive section:
[img:484:233]http://i269.photobucket.com/albums/jj55 ... rdrive.jpg[/img]
Schematics of Dumbles I've seen have caps in the same places but are 350pF. Are these for smoothing? Or do they have some other purpose?
Re: Smoothing caps?
Commonly known as snubbers.
They do indeed smooth the top end.
Re: Smoothing caps?
Great! I thought that might the case. It's the only real difference I can find in Dumbles and various clones compared to other amps. I built a single ended amp and have been trying to get a smoother sound. I tried 270pF and they seemed to smooth it a little, so I put 500pf caps in it. Sounds great. I compared it to an older amp of the same design and it does indeed sound a bit smoother, but I was wondering if it was just "voodoo", you know.
Thanks, Tom!
Thanks, Tom!
Re: Smoothing caps?
Never seen 350. I have seen 250pf and 330pf in many. RF has 250pf.
sepulchre wrote:I saw this in a D'Lite schematic in the overdrive section:
Re: Smoothing caps?
[img
792]http://i269.photobucket.com/albums/jj55 ... Hybrid.jpg[/img]
I also saw a Dumble schematic from the '70s with 500pF snubbers.
Re: Smoothing caps?
Most of these schematics have mistakes as well as artistic liberties of the drawer.
Don't trust them as gospel.
Re: Smoothing caps?
I don't, but 500pF does work very nicely.
Re: Smoothing caps?
I found that 500pF killed that nice "chirp" on the notes attack. 270 to 330 seems to be the range that I like.sepulchre wrote:I don't, but 500pF does work very nicely.
Re: Smoothing caps?
For whatever reason, the particular parts, brands, etc. I used building my amp, it has a Lot of high end. If I want more 'chirp' I can crank the treble on the amp, or turn up the tone on my guitar. I run the amp's treble at just under half and the guitar's at just over half. So there's still plenty to be had. If it were another amp I would probably go with 270 or so.
Re: Smoothing caps?
You might search on the word "snubber".
Re: Smoothing caps?
FWIW I tried a nice Two-Rock that had 470 pF snubbers on both OD stages.sepulchre wrote:For whatever reason, the particular parts, brands, etc. I used building my amp, it has a Lot of high end. If I want more 'chirp' I can crank the treble on the amp, or turn up the tone on my guitar. I run the amp's treble at just under half and the guitar's at just over half. So there's still plenty to be had. If it were another amp I would probably go with 270 or so.
Although I tend to agree that this is too big in many amps, in this case it sounded really good (low-plate skyliner, a schematic of this particular amp
was posted by Novosibir a long time ago).So if it sounds good to you,go for it
Trust your ears, Marcos
Re: Smoothing caps?
Iirc, the snubbers are common to high plate non-hrms, though they're really just one of the tools in the box.
Re: Smoothing caps?
mismatched snubbers are the key to smooth tone without losing chirp IMO. Im running 830pf on the second triode and nothing on the first. Sweet open goodness with plenty of warmth without getting too dark and honky. I use teles BTW so a LP player might want a lower value closer to 500pf
It's true i've lost my marbles and i cant remember where i put them
Re: Smoothing caps?
I've got 500 pF on both. Maybe I should try some alteration, like 270 on the first and 680 on the second. That's what I've got on hand.
Thanks for the tip!
Thanks for the tip!
