Is this a problem?
gary sanders
Is this a problem?
Post by gary sanders »
I was cleaning up the chassis and moving a few wires around and by accident when I was checking bias current I noticed when the presence control was turned all the way up the bias current goes up a few like from 25 to 30.It only does it when the control is turned from about 75% to 100%.I was wondering if thats normal or do I need to look at something.
talbany
Re: Is this a problem?
Post by talbany »
Gary
Sounds like you could have some sort of internal oscillation happening when you decrease the GNFB..Could of been induced when you were moving those wires
gary sanders
Thanks man,I'll get out the chopsticks and see if it helps.
Was definitely a what the hell moment
gary sanders
Final Edit: 55v bias winding is shorted out......damn it.Continuity to ground. :?
Time to buy a PT I guess.
BobW
Post by BobW »
Gary, You don't need a bias tap to create a bias voltage. Just use the circuit shown here:
http://www.drtube.com/schematics/ampeg/v4bpwr-jp.gif
You may want to change the 75k to a 68k + 10k pot or similar to adjust the bias.
Bob-I
Post by Bob-I »
gary sanders wrote:Final Edit: 55v bias winding is shorted out......damn it.Continuity to ground. :?
You sure? The bias winding is just a few ohms, a continuity meter may beep even if it's good. If it's really shorted to ground you have no choice but to replace it, but I'd check more before spending the bucks.
talbany
Post by talbany »
Weird.. none of these problems really explains the interaction of the Presence control in the first post.. :?
jelle
Post by jelle »
talbany wrote:Weird.. none of these problems really explains the interaction of the Presence control in the first post.. :?
+1. Check leaddress.
Jelle
