I had a bad power transformer in my first build twin type. I striped the amp today
What I have on hand is Marshall JTM45 set, 1202-118 power, 784-103 output, and choke.
My problem is the Marshall power transformer is wound 180 degrees different from a fender power transformer
Will the magnetic flux induce noise on the stock transformer layout per Dumble style chassis?
Should I get a fender 125p7d-022814 power transformer bandmaster/ bass man type?
Or will the Marshall iron work? Next the choke the stock jtm45, c-199 and I have a fender 22699.
Thank you, Steve.
Transformer orientation
Re: Transformer orientation
Steve
I think you should be fine like it sits..
I wil give it a try.
Thank you, Tony
Thank you, Tony
The major flux density will be vertical with a laydown PT, so above and below your amp.
As Tony said, it should be fine.
deleted.
I need to learn to read fully before I post!
