High Voltage Non-HRM 100W Build Started
MM style high voltage power, high plate skyliner, FS mid boost and 6V regulated relay supply.
TM
						TM
						Re: High Voltage Non-HRM 100W Build Started
PEC pots?
Looks NICE!
									Looks NICE!
Lookin good!
So no FET?
Is the relay on the right sidewall for the mid boost?
Hey, I just noticed something, you only have six of the radial filter caps verses eight on most amps.
Can you explain that?
 So no FET?
I see another blank board on the sidewall...I'm guessing switchable FET boost...
									"...& I'm all out of bubblegum"
Tom, I have so much going on I really haven't had time to tweak those PCB files for dual inline relays or order the FET pcb board. Thus I ended up making those boards via G10. I was going to use a pcb FET, but when I looked at the Ceriatone layout yesterday I said I can make an FET board real quick.Structo wrote:Lookin good!
So no FET?
I tell you this pcb boards are the way to go, even using a respirator the G10 dust is nasty.
Yes, the small relay board is the mid boost relay and the plan is to mount the FET board at the right rear of the chassis.
The MM topology taps off the screen voltage between the first two big caps. Since I'm feeding my screens directly via a bigger choke, I really don't need to you use four radial banks.
The first board that I punched two weeks ago had 4 radial banks as I was thinking about running all nodes through a bank. So when I drilled the board mounting holes the chassis was mocked up and clearanced with Alpha pots. Well when I installed the PEC pots the power board butted almost right up to the deeper PEC pot. Thus, time for more G10 dust
 Basic MM power plant
B1: 700 volts, first cap
B2: 350 volts, betweeen big caps, feeds screens (i'm also using a choke inline here)
B3: output of 25K 10W resistor
B4: post 15K resistor
B5: post 10K resistor
I did add a resistor post the 25K so that I could tweak the preamp string without having use the 10W as the adjuster resistor.
Mike
Made a bit more progress, the power section is wired minus the heaters, standby switch and screen resistors.
				Drumslinger
that's looking pretty sweet TM.
What layout did you end up using for the big filter board?
Power Works
It passed the smoke test
Unloaded voltages @ 123.6 VAC
B1 = 767 VDC
B2 = 383 VDC
Htr = 7.02 VAC
Relay PS = 6.03 VDC
Bias sweep @ wiper leg = -34.8 to -43.2
B1 = 767 VDC
B2 = 383 VDC
Htr = 7.02 VAC
Relay PS = 6.03 VDC
				Drumslinger
have you slept any TM?  Looks like your putting in some overtime on that amp.
Looks good.
Keep 'em coming.
						Keep 'em coming.
Sleep is way overrated and besides, I'll have plenty of time to sleep when I'm on the other side of the dirt and my toes are pointed up!Drumslinger wrote:have you slept any TM? Looks like your putting in some overtime on that amp.
 Actually, I worked on it just little bit this evening after dinner. I only wired up the standby, turned a diode around and swapped two lead locations. I still have v1 thru v6 heaters and screens to finish up the power section.
The act of seeing 700+ volts was eating at me all day and I couldn't wait, I had to power it up.
Mike
My version of MusicMan 100W iron showed up today from Heyboer and I've finally finished the preamp board.
Plates: 150/120 & 220/150,
Cathode caps: Sprague TE 5uf
Cathode resistors: Dale CCF60
Signal resistors: Speer & Electra/Mepco CF
Orange drops: combination of 225P, 6PS, 418 & 220P
TM
TM
What is the huge cap on OD1?
Structo wrote:What is the huge cap on OD1?
.015 16PS
