Filter caps max uf for ODS
gary sanders
Is 40uf too much for the 124 ODS? I got a steal deal on a handful of Atoms and was going to use them in my new build if they'll work.
Re: Filter caps max uf for ODS
should be fine as long as you dont get into crazy high values. The more filtering the more headroom, and tighter bass you'll have. It should reduce the ripple as well.
I think i have 40uf or 50 in my amp
It's true i've lost my marbles and i cant remember where i put them
gary sanders
Cool.Thanks for the info!!!!
- David Root
Are you talking V1 & V2 and the PI?
I have a bunch of blue Sprague Atoms I would love to get rid of, they are way too big for what I'm doing. These days those are just small modern caps inside a '50s dimension can, with no cap cooling thru the can which is not good for long life. If you want 'em I have some.
gary sanders
Yes,Id like to get them.Im going to build a few Champi-ish amps for some people for christmas gifts so i could use them.Send PM
What do you perceive when you do that?ampdork wrote:Give 40's on V1+2 a try....
