What makes this sound?
LPSGME
Post by LPSGME »
talbany's recent Beck emulation post reminded me of a Laney demo clip I always found interesting, particularly for the intermodulation/rupture of the sound at the close of some of the notes.
Does anyone have any thoughts about what does that, or how to do it?
Mouse over the lower middle amp panel where the info scroll bar is and select Track #3.
http://www.laney.co.uk/flash/audio/L5T- ... &width=760
stelligan
Re: What makes this sound?
Post by stelligan »
Some of those sounds can be made by "triggering" the whammy bar or flicking it. Other splatty sounds are generated by picking and the gain of the amp, I would assume.
bluesfendermanblues
Post by bluesfendermanblues »
Sorry for OT remark
The drum sounds on track 3 are not bad either. Check out the kick drum sound........ :shock: ...I've been tying to get that sound out of my old Ludwig for 5 years with all kinds of mics and compressors and Eqing.
:wink:
mr_hankey
Post by mr_hankey »
You push the whammy bar down, and quickly pull your hand off it, so it springs back by itself.
gilgalad101
Post by gilgalad101 »
Very David Gilmour-esque.
selloutrr
Post by selloutrr »
it sounds like a 24" or 26" x 22" kick with a pillow of foam strip hard beater head.
it's not a hard kick sound to get!
use mic placement and subtractive eq not boosting!
use two mics one on the inside of the drum to capture the beater and pump and another on the outside of the beater head to fill in the snap and air. align for phase shifts to taste.
compress 4:1 - 8:1 depending on dynamics.
personal fav mics.
inside: AKG D12e, Shure Beta52, Beyer M88, Shure SM88 (as long as the drummer isnt a monster this mic is awesome!!!) SM91, D112.
outside: Neumann U47fet, Beyer M88
route a little to the Overhead reverb to glue it in the mix
Other easy way!!! for all you protools mix in the box guys sound replacer :wink:
My Daughter Build Stone Henge
selloutrr
Post by selloutrr »
the clips remind me of top gun and cinemax soft core porn from the 80's. ebow anyone?
LPSGME
Post by LPSGME »
bluesfendermanblues wrote:Sorry for OT remark
:wink:
Now you have me wondering what drums would sound like re-amped through a Dumble - for a Drumble sound?
bluesfendermanblues
selloutrr wrote:it sounds like a 24" or 26" x 22" kick with a pillow of foam strip hard beater head.
it's not a hard kick sound to get! use mic placement and subtractive eq not boosting!
personal fav mics.
@selloutrr, thanks for the tips
selloutrr
Post by selloutrr »
No problem :). The trick is to get that beater attack from mic placement so get just the littlest bit of Chain movement then compress for that solid pump and click. My guess is when you are mixing you solo it up and get a really nice kick sound then when the drums are put in the mix those suddly bits or character are lost. If you mix just a bit extreme they seem to be just right after everything else is unmuted.
Just becareful of sub harmonics and low mid mudd some speakers can't reproduce.
