Funks chassis shows three switch holes. Bright, mid, and jazz/rock. There are Five switches shown on the Rev A schematic. I would like to put my bright on my global master (1 meg audio) and the deep on the Bass control. Both pull type. I will use the hole labeled bright for HRM, mid for mid, and Jazz Rock for Jazz rock.
These pot switch combo's don't look easy to find.
Dan
Where in the heck are you finding pots with pull switches?
- skyboltone
Re: Where in the heck are you finding pots with pull switches?
Mouser has Alpha push pull pots.
Doug Hoffman has a couple values of CTS SPSTs and the usual 250k, 500k DPDTs.
The "boost" switch is generally relay-controlled, not a physical switch. (aka PAB - the one that lifts the ground on the tone stack)
Me: Just one more...
