Lowering B+
Blindog
Lowering B+
Post by Blindog »
I've been tweaking my 50W non-HRM dropping string, and I have my voltages where I'd like them to be with the exception of the output tube plate voltage: 495V (6L6's) Here's what I have with 121V AC line voltage, under load:
PT Sec: 375AC
B+1 496
B+2 493
B+3 432
B+4 325
B+5 318
Dropping string is 390R choke resistor, 8.2K, 22K, 2.2K, 150K FET
I've been through a bunch of threads that helped get the downstream voltages where I want them, I just need some ideas to lower the output tube plates. My PT is from an early '70's Bassman 10 that was the donor amp.
I thought I read somewhere about using a zener diode somehow to achieve this. :?:
Thanks!
talbany
Re: Lowering B+
Post by talbany »
Yes the best way is to use a zener diode on the CTof the PT.. Weber sells them I have used a couple for some EL-84 amps...They will drop about 30v on Plates..
mlp-mx6
Re: Lowering B+
Post by mlp-mx6 »
If you do that it will drop everything else too, so plan to rework the dropping string a bit after you install that.
OR you could just tweak it to make it sound good with the voltages as they are now...
Me: Just one more...
brewdude
Re: Lowering B+
Post by brewdude »
In my limited understanding, I would think that the higher PA plate voltage would provide a cleaner power section with more headroom, witch seems to be desireable in a D'style build.
talbany
Re: Lowering B+
Post by talbany »
With the Weber zener installed your voltages will still be a llittle high like 470v (which is fine) so your first dropping string will need to be more like a 5K or 6.8k in that area to get you down to about 290-300v for the PI for max headroom.... From there you can continue on down with the 22K 2.2k 150K.. Good Luck!!
Blindog
Re: Lowering B+
Post by Blindog »
talbany wrote:Yes the best way is to use a zener diode on the CTof the PT.. Weber sells them I have used a couple for some EL-84 amps...They will drop about 30v on Plates..
Cool, thanks Tony. I knew I saw it somewhere!
I've read where some can hear a difference in amps with the higher than the average plate voltage. Guess i want to bump it down and hear for myself :) I'll play the amp for a while with these new tweaks before I try the zener trick.
kd
Re: Lowering B+
Post by kd »
You can use a string of zener diodes to increase your wattage handling capacity. It can also be placed in line after the standby switch. Make sure the cathode end is facing the towards the switch.
Another way is the R.G. Keen method using a mosfet and zener diode. See attachment below.
Ken
greiswig
Re: Lowering B+
Post by greiswig »
Blindog wrote:I've been tweaking my 50W non-HRM dropping string, and I have my voltages where I'd like them to be with the exception of the output tube plate voltage: 495V (6L6's)
Man, I'd like to have your problem. If I were in your shoes, I'd tweak the amp to run KT88s, leave that PA voltage where it is, and enjoy. I'm running my amp with 88s at 432V, and wish they were a bit closer to 500.
Seriously, I think the power amp is happy with the additional headroom. The plate voltages for tone that you need to concern yourself with are mainly in the preamp and PI, IMHO.
-g
Prairie Dawg
Re: Lowering B+
Post by Prairie Dawg »
You can obtain similar zener diodes in any flavor you like from Mouser. I've used them to drop the B+ on a Rose Morris AC30 from 395 to 320 with no trouble at all. It's best to find a nice quiet place with some steel around it to soak up the heat because it will throw the excess voltage off as heat. That and using a good heat sink compound and you're good to go. It's like dial a voltage.
I did obtain a Weber V-dump and I didn't much care for dumping all that excess heat into the power transformer.
If you believe in coincidence you're not looking close enough-Joe leaphorn
talbany
Re: Lowering B+
Post by talbany »
If your looking to dump 30 volts in a 50w amp..the power rating for the Zener is 6 watts.
.The Weber V dump comes with it's own Heat sink.. I don't see where your dumping heat to the P-Trans..
KT-88 in D-Style= Sweet
Blindog
Re: Lowering B+
Post by Blindog »
Interesting, I never even thought about that possibility. 8)
You just reminded me that I have a pair of GE 6550's in my tube box that I should try out. What kind of tweaks did you do to your amp? Where do you like your bias set?
Thanks!
MArk
Re: Lowering B+
I used a 25v 25w Zener on a 6V6 amp I built.
I used an old Hammond organ PT which put out over 480v.
I used the chassis to mount the stud type Zener and it worked great on the CT.
It does get pretty hot.
If you use a stud mount be sure it is the negative ground type (cathode to case) and use heat sink compound on it when mounting it.
greiswig
Re: Lowering B+
Post by greiswig »
Blindog wrote: Interesting, I never even thought about that possibility. 8)
Thanks!
MArk
Mark,
I have a pair of Tung Sol 6550s, and I very much prefer KT88s in this amp...either the Winged C or Pentas. The 6550s seem to have a quality that I just don't care for; they kind of smack you in the face, and not in a good way. But that might just be this particular brand.
Anyway, the grid resistor was the only thing I changed: I made it switchable between 6L6 values and 6550/KT88 values. See https://tubeamparchive.com/viewtopic.ph ... stor#70508 for some more detail.
-g
Blindog
Re: Lowering B+
Post by Blindog »
Thanks!
MArk
Mark,
Thanks for that. I 'm going to try some KT88's. I have to get some some spring retainers to try out my 6550's. Those things are huge.
talbany
Re: Lowering B+
Post by talbany »
Just make sure your Output transformer can handle the extra power.. 2 KT-88 @ 500v give you almost 80 watts RMS..
