First #124 base build
67plexi
Post by 67plexi »
Chassis fits the case, most of the amp is wired, I Still have to make the fet , The 4 bolt handle should arrive next week, Light weight pine head box. Twin transformers. Gut photos to follow. Thanks to all of you.
Steve.
gilgalad101
Re: First #124 base build
Post by gilgalad101 »
Looks good. Where did you get the cabinet?
67plexi
Post by 67plexi »
Thank you I made the cabinet.
Steve.
v00d00blues79
Post by v00d00blues79 »
Where'd you get the suede? if you don't mind me asking. I'm looking to get some for a couple cabinets I have planned.
Thanks!
Andy
Deric
Post by Deric »
Looking Good! 8)
Deric®
67plexi
Post by 67plexi »
Thanks!
Andy, I had two hides the problem is the thickness varies and flaws in the Swede
A friend gave me the hide’s years ago, you might try Tandy leather $2.79 per square foot.
Also use carpet & sheet vinyl adhesive it is cheap and works well
Regards, Steve.
Steve, the amp is looking good. :)
I love the suede look especially the yellow stuff Jelle uses but man suede can get so dirty and be a bitch to keep up. :roll:
Good looking amp head. Looks like the real deal. :D
67plexi
Post by 67plexi »
The parts to finish this amp have arrived. I hope I can get a good slide tone out of this amp, one with single coil pickups. I have a matched quad of U.S.A. 6l6gc, 3 each 7025s to start with.
It’s sad that a quad of GEC kt-66s won’t fit in the chassis one of my favorite power tubes
The cabinet is finished. Thanks to all.
Steve. :wink:
BobW
Post by BobW »
P-90s are the answer to a great tone slide (think Sonny Landreth) with the #124.
Richie
Post by Richie »
you might try using this place for covering material. they have about everything, snake, lizard, ostrich, crock large and small, suede, pleated,
basketweave,and about every color type you could think of, some would also make great basketweave grillcloth etc..
glitter, metal looking,
just have to look through all the cool stuff
http://www.garysupholstery.com/suede.html
ToneMerc
n/m
Post by ToneMerc »
dup
ToneMerc
Post by ToneMerc »
Richie wrote:you might try using this place for covering material. they have about everything, snake, lizard, ostrich, crock large and small, suede, pleated,
I got a few samples of that faux suede back in the Fall. If you really got to have the depth and texture of real thing, go with real suede. It's a PITA to find enough hide to get sq footage to do an amp though.
FYI, if you email them they will send out samples that same day.
TM
67plexi
Post by 67plexi »
Thanks to all.
Steve. :D
talbany
Post by talbany »
Steve
Sweett!
T
