Maybe that's why I shouldn't be doing this at 4:00 in the morning. Stupid question should I be measuring AC or DC in that case?martin manning wrote: ↑Sun Jan 17, 2021 3:08 pmYou're off by a factor of ten. You want to see 1.08 volts across the 13.5Ω side of the OT.professormudd wrote: ↑Sat Jan 16, 2021 10:20 pmI recorded 14.5R and 13.5R. Amp off, unplugged, tubes in...
...I did your procedure as follows:
13.5R, 40mA (13.5 x .004) = 0.054, giving me .108 per side.
I only have one bias pot on this amp. Clipped my common lead to the standby switch, clipped other lead to pin 3. Everything was turned all the way down and I adjusted the pot until I got around .108.
ODS 124 PCB Build
				professormudd
Re: ODS 124 PCB Build
									-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
DC. You're just using the DC resistance of the OT primary in place of the 1Ω current sensing resistors on the cathodes. Note you'll get plate current only using this method, so I'd target about 55% of Pd max (which is 30W for 6L6GC). That's 0.55*30W/450V = 37mA, so set 2*0.037A*13.5Ω = 0.999V on that side. After you've done that, check the B+ to see if the estimate of 450V at idle was good.
				professormudd
The idle was 457 volts. So then I would get 36mA. Which comes out to .975 volts.martin manning wrote: ↑Sun Jan 17, 2021 4:14 pm DC. You're just using the DC resistance of the OT primary in place of the 1Ω current sensing resistors on the cathodes. Note you'll get plate current only using this method, so I'd target about 55% of Pd max (which is 30W for 6L6GC). That's 0.55*30W/450V = 37mA, so set 2*0.037A*13.5Ω = 0.999V on that side. After you've done that, check the B+ to see if the estimate of 450V at idle was good.
I will set that value. Thank you.
-Matt
				professormudd
Okay I got that value set. I still have the hum issue that I'm looking to figure out as well as the PAB and OD relays not working.
Does anyone have suggestions as to what to check?
-Matt
You said you confirmed 12vDC for relays. Are the relays actually functioning? When you flip your switches, can you hear the relays click? Use your multimeter to confirm conductivity of relay terminals in open and closed positions.professormudd wrote: ↑Sun Jan 17, 2021 6:28 pm Okay I got that value set. I still have the hum issue that I'm looking to figure out as well as the PAB and OD relays not working.
				professormudd
I did confirm 12vdc on the relays at the diodes. The side with the stripe, closest the the front of the chassis reads 12.07vdc consistently. The other end of each diode reads 12.07vdc when the switch is set to pedall, 0.5mVDC when manual. I cannot hear either relay click. I do not get a change in continuity either. I believe the switches are fine. I wonder if my relays were not the right ones.xtian wrote: ↑Sun Jan 17, 2021 10:03 pmYou said you confirmed 12vDC for relays. Are the relays actually functioning? When you flip your switches, can you hear the relays click? Use your multimeter to confirm conductivity of relay terminals in open and closed positions.professormudd wrote: ↑Sun Jan 17, 2021 6:28 pm Okay I got that value set. I still have the hum issue that I'm looking to figure out as well as the PAB and OD relays not working.
									-Matt
				Richard1001
                                            2 others liked this
You have latching relay's. This means that the relay switches when you apply a voltage pulse and stay's in the same position untill you apply a pulse with reversed polarity.
You need a non-latching relay that switches if there is a voltage applied and switches back when the voltage is cut off.
				professormudd
Thank you for the reply.Richard1001 wrote: ↑Mon Jan 18, 2021 12:36 am You have latching relay's. This means that the relay switches when you apply a voltage pulse and stay's in the same position untill you apply a pulse with reversed polarity.
Will these work?
https://www.mouser.com/ProductDetail/om ... cycode=USD
-Matt
That looks right to me. Others will confirm.professormudd wrote: ↑Mon Jan 18, 2021 12:41 amWill these work?
				Richard1001
Yes, these will work.
				professormudd
Cool. Looking forward to figuring out how to install these with the board wired in. I got the old ones out, but the holes have a little solder in em. Not sure how to properly empty these tiny holes to make room for the pins.
									-Matt
				Richard1001
		- pompeiisneaks
- Site Admin
This is my favorite one:
https://www.amazon.com/Engineer-SS-02-S ... 907&sr=8-4
comes with silicone tip instead of plastic so it lasts a ton longer.
Any of them do the job though.
~Phil
~Phil
tUber Nerd!
				Richard1001
Also: have you wired the diode that's on the relay the right way? It looks like the anode is wired to the red wire and if red represents positive, the diode needs to be reversed. The diode over the relay coil needs to be in reverse: anode to ground and cathode to positive.
