Dumbleator Layout
Dumble schematics, designs, pictures. Only members may post files here.
Steve AA1164
Re: Dumbleator Layout
Post by Steve AA1164 »
Thanks Martin,
" FW Doubler will produce (120*1.414 - 0.7)*2 = 338 VDC." I got mixed up with the Ripple voltage of 3.2 x the load current. I've read up on ripple current and have a better understanding now.
Thank you for the PT recommendation, I'll consider building a tag board FBR for the E-lator PCB or ask Modulus or Ceriatone if they have a PT with the correct values.
Regards,
Steve
Steve AA1164 wrote: Sun Jul 13, 2025 9:55 pm I'll consider building a tag board FBR for the E-lator PCB or ask Modulus or Ceriatone if they have a PT with the correct values.
It'd be nice if you could use the power supply components on the PCB you have. Here is another option for a D'lator PT that has been proven to work: https://ampgarage.com/forum/viewtopic.p ... 79#p464179
Don't know if you can get that part shipped to AUS, and note that in that thread the C-lator PT was found to be junk.
Steve AA1164
Thanks Martin, I've ordered the 1N1729
1n1729.pdf
Regards,
Steve
Steve AA1164
I've just edited my post on page 5 dated Sun Jul 13, 2025 3:20 pm. How do we get to the 365V B+ listed on the schematic with a PT secondary of 125V AC. Something to do with my understanding of the voltage doubler CCT. Would someone be able to check my workings out and point me in the right direction?
Edit....
I just re read Martin's post. "A 120VAC secondary with a FW Doubler will produce (120*1.414 - 0.7)*2 = 338 VDC."
So (125*1.414 - 0.7)*2 = 352.1 Vdc. This is close to the 365 V dc B+. The 2k2 2W is a series limiting resistor to limit the amount of current flow through the diodes (1N4007 rated at 1000V 1A) and also drops the voltage by 5V to get to the target of 360 B+1.
I think I'm on the right track?
Regards,
Steve
