SSS 002 LAYOUT
SP-117
Does anyone know where one would purchase the SP-117 Inductor for this circuit?
Re: SSS 002 LAYOUT
It is a discontinued Triode part - keep an eye out on eBay. Or, sub another similarly spec'ed inductor.
Re: SP-117
marshamps wrote:Does anyone know where one would purchase the SP-117 Inductor for this circuit?
https://tubeamparchive.com/viewtopic.php?t=17813
Scroll through I believe there's suggestions for alternatives. I found that Triad SP-117 inductor once, the cost was outrageous though.
TM
Re: SSS 002 LAYOUT
Thanks Gents! If i can find the specs, perhaps we can have a few made for everybody!
Re: SSS 002 LAYOUT
900mHmarshamps wrote:Thanks Gents! If i can find the specs, perhaps we can have a few made for everybody!
TM
Re: SSS 002 LAYOUT
I don't use the inductor and my step filters work just fine...
There was someone a while back who did some SPICE simulations which revealed pretty much no difference between using an inductor or using a 100k resistor...
TT
TT
Re: SSS 002 LAYOUT
This is the inductor I'm using, dirt cheap made in china. triad RC-5. 915uH
Re: SSS 002 LAYOUT
I believe it's gotta be .9h I saw the Spice sims that were posted and agree not any diference from a 50 ohm resistor or wire, but as long as wer are trying to be accurate..
Re: SSS 002 LAYOUT
Using china parts looks I was wong
. It's been 32 years since I have used inductors or choke coils. Panasonic makes a choke coil 8200uH or 10,000uH. .820H or 1.0H
Re: SSS 002 LAYOUT
Most likely, but that is really expensive for what it is (especially if you are not in the EU)
Re: SSS 002 LAYOUT
I'm confused. Is the inductor
900uH
or
900mH
It doesn't seem to say on the schematic and I can't find a spec sheet for SP-117.
Eric
900uH
or
900mH
Eric
Re: SSS 002 LAYOUT
1H = 1,000,000 uH67plexi wrote:Using china parts looks I was wong. It's been 32 years since I have used inductors or choke coils. Panasonic makes a choke coil 8200uH or 10,000uH. .820H or 1.0H
