Reeltarded wrote: ↑Thu May 02, 2024 6:02 am
dorrisant wrote: ↑Fri Apr 26, 2024 10:48 am
If you've ever bought anything from IK, you may have "jam points". I applied mine for a $54 discount buying the ToneX One directly through them.
I need you to do me a favor, please.
Disable cabs and play ToneX through effect return to power and real cab. Do you have any of the add-on amp packs? I want to know if global cancelling kills all cabs.
This is a real problem for these devices overall. If the cabs can't be killed the amps are useless to me.
Pic is from the QS Guide...
Also, the ToneX Pedal works the same.
This depends on if the amp is captured by itself or with effects or cabs. Most, if not all of the Max version of the software (free with the pedal (even used)) have them separated. I haven't looked through all to verify.
The models from the ToneNet... Some a very good. Others could have been captured better, like excluding the pedals or cab. Some of these are modeled directly from a QuadCore.
But this thing (One) is ridiculous. You only get the SE version of the software, but to tell you the truth, the out of the box setup is hard to stop playing. It is a Super on ch1 and "Just800" on ch2. Since I already have the Max software, I'll load it up with some of the premium stuff.
Check out the "Premium Tone Modes" list below. You can see if they have the cabs with them or not.
I have played a lot of the models and find them all very realistic, even the ones I don't like sound just like the ones I don't like.
Next I will capture some of my stuff. Also, I have to look at the file type here and see if it is portable. Anyone else know?
