Great! Another good option. I will also try this.martin manning wrote: ↑Mon Jan 10, 2022 5:46 pm Another thing you can try is lowering the primary impedance on your 125B output transformer. There is a 17,600 option with an 8Ω load (violet and green secondary leads) which might sound good. This and the output stage idle bias are things that you should use listening tests to make the final selections. In my opinion it's easiest if you can get a really good player to help you out with that.
EF80 based power amp for guitar
