My point exactly Marcus. Easy to test too. If you still see blue flashing, but get no intermittent sound, it probably isn’t arcing (I think). Especially if it is all tubes at the same time like you said. If in doubt: upload a short video.norburybrook wrote: ↑Wed Jan 29, 2020 1:47 pmunless the arcing i saw was just regular blue tube light but caused by the loud crackle the reverb cable was causing when the dimed amp was vibrating it?martin manning wrote: ↑Wed Jan 29, 2020 1:02 pmSeems unlikely that a small signal issue would be the cause of the arcing you saw. Intermittent faults are the worst...norburybrook wrote: ↑Wed Jan 29, 2020 8:44 am Martin, thanks it's a 500v cap too and that was the highest I could find , but yes it's on it's limit. Now I've removed the chassis bolt and replaced the phono socket on one of the reverb cables the amp has been perfect again all afternoon, no problems at all.
Intermittent problems are indeed the worst
M
Standup transformers are my favourites. More room inside. Less possible interaction with reverb tanks. Just some holes for mounting and wiring, so easier to diy. Only downside I can think of is height in combination with a reverb tank in a head shell. Might be tight...
