Pignose G40V Project
Littlewyan
Re: Pignose G40V Project
Post by Littlewyan »
I tried playing through mine again tonight but its just........blurry. Not a great way to describe it but there is no definition when playing chords at all. Tightened all the screws up holding the cab together so its pretty solid. I may have a different speaker to you by the way as I heard they changed speaker at some point during production.
I think I'm going to go for the Vintage G10. There is one on ebay, its available and should give me a sort of Vintage 30 sound. If I want the G12M sound then I can plug into my 2x12.
Littlewyan
Found the oscillation. It appears on the Anode of V2A going into the grid of the Cathode Follower.
Fixed the issue with a .001uf Plate Bypass Cap. Oddly enough this person had the same issue on a real JCM800 https://tubeamparchive.com/viewtopic.php?t=27113
Now that I've sorted the oscillation it has more high end in a way. When you turn everything up on 10 it squeals unless I run two long cables in series for the guitar. The fix for that is a 100pF cap across the Plate and Cathode of V1A but I'm not fussed about that as I always run two leads anyway.
L
Post by Stevem »
One thing to try to get rid of that is to place a .005 cap off of the tip of the input Jack in series to ground with a 47K resistor , then you might just beable to plug straight in with one cable!
Littlewyan
Ah never heard of that before. Will have to try that.
Fitted the new speaker tonight. I must admit its not a massive improvement. In fact it doesn't sound that different! Then again I haven't heard the other speaker since early last week and my bedroom is quite small and usually makes amps sound pretty poor! I guess the real test won't be until I get it to my band's rehearsal room.
