Use of the UL Tap drops output impedance by a factor of about 3 over Pentode connection. That means that (in general) you do need to ditch any global feedback loop - you just don't need it with UL connected output tubes. Size your screen resistors (from g2 to UL tap) to suit the level of compression you want, don't be afraid to really try some bigger values. 1K is minimum for EL34 but try 2K2, 4K7 etc. you just may like it.TUBEDUDE wrote:The best sounding twin reverb I ever heard was UL. The key was trashing the feedback and cathode bias portion, returning to straight fixed bias. Besides the reverb sounds best delivered to the other input to the phase inverter. It sounds good even at lower volume but is certainly overkill for small gigs, but the owner does mainly big stage and outdoor gigs. Sorry Reel, I guess we don't all share the same tonal ideals, I just can't believe you wouldn't love the tone also. How do you feel about the new UL Tone King amps?
Ian
