Looks great steve
glad to hear its sounding good.
I noticed you used resistors for the heater tap instead of the transformer center tap.
What cab/speaker(s) you have?
Again nice job.
Darin
						70's 100 Watt Hybid Started
				dcribbs1412
Re: 70's 100 Watt Hybid Started
Hi Darrin,
I did use 121 Ohm - 1% resistors to ground reference the center tap.
I was going back and forth for awhile, but my take from reading some respected builders posts here is that the resistors are the way to go.
I have 2 cabs to chose from, a single 12 with an EV 12L and a 2x12 loaded with Heritage G12-65Hs.
Both cabs were made my TAG member Super100. Highly recomended.
I just hapened to have a 22k - 3W resistor left over from my z-wreck build awhile back, so I subbed that in and my voltages came up a bit.
I didn't chart them all this time, but i believe my V1 Plates were about 190 and my V2 plates were about 198. I am not going to mess with it anymore at the moment.
Got the chassis loaded into the cab...now I need to start playing alot.
Oh yea, and I need to build my mini-dumbleator (ala Martin Mannings layout).
				dcribbs1412
Last pic looks like a really nice match
congrats...Whats next...102 maybe
Darin
 Darin
Not sure...I have a 124 that was my 1st and only other d-build. I haven't done a high plate amp yet, or one with el34s.... 183 may be in the cards next. But, I would be interested to try a 102 also...that has the high plate loads too...and the soft filtering.dcribbs1412 wrote:Last pic looks like a really nice match
Darin
I may just need to build both. Man this is an addictive hobby.
Hmmm...
So I was playing the amp today when the fuse blew.
I only had a 3A fuse in there, so that may have been slightly under rated.
I will pick up some 5A fuses for replacment.
However, it appears that one of my power tubes is not working correctly.
I can not see the filament glowing in 1 tube, and I am not reading any voltage across the 1ohm bias resistor for that tube. The problem travels with the tube when I switch positions.
All others seem fine.
I will admit that when I fired up and checked my bias reading, I only checked 2 of the 4 tubes, so this problem may have been there from the start. I can not be certain.
Tubes are Tung Sol 6l6GC-STR Reissue tubes.
I put an email into CE to see if they will replace the tube or the set.
Minor update:
Popped in another set of tubes and checked voltages, everything looks fine.
Could have just been infant mortality on that tube.
Strange.
Strange.
looks great, a 3A slow blow is all you need.steve_p wrote:Hmmm...
TM
Thanks tm.
I looked at pictures i took last night and it definitely looks like all four filaments were lit.
I wonder if that tube crapping out was what took out the fuse.
I couldn't find anything wrong inside the chassis.
Oh well, I'll have to keep an eye on it.
Good possibilitysteve_p wrote:Thanks tm.
TM
