EL84hrm
Re: EL84hrm
Very grateful!!   Thanks for sharing it.  Very kind of you.
With respect, 10thtx
				dcribbs1412
Re: EL84hrm
Thanks for sharing
going on the list
						going on the list
Re: EL84hrm
Colossal;
Dave is this one different then the one I have already?
Re: EL84hrm
thanks for sharing....nice drawing too...BTW
									The Blues is my Business....
and Business is good.....
Re: EL84hrm
Hi Mark,M Fowler wrote:Dave is this one different then the one I have already?
Yes it is different. The one posted reflects the specifics of Mat's amp. The one I sent you is just stock 101HRM mated with the stock AX84 power amp. Mat made quite a few changes, tailoring the HRM to his tastes (very tasty!) and is also using a different PT and a modified power supply.
Re: EL84hrm
Thanks Dave, now the secret is out about your great schematics
Nice work as usual.
 Nice work as usual.
Re: EL84hrm
What did you use for the drawing?
mini-HRM questions
Is the bright switch on the volume a DPDT with center off?
How much of the time do you use the mid boost?
What is the purpose of the 22M resistors on the PAB switch?
The grid resistance value going straight into the EL84 is 280k & there is
no dropping resistor to ground like you'd see on a Hi-Octane. Correct?
(with cathode not fixed bias)
with respect, 10thtx
Re: EL84hrm
I use EazyDraw for Mac. <i>Very</i> powerful and easy to use.danotron wrote:What did you use for the drawing?
http://eazydraw.com/
Re: mini-HRM questions
10thTx, yes, that is a center-off switch. I will update the drawing to reflect it.10thTx wrote:Is the bright switch on the volume a DPDT with center off?
I saw that myself but copied Mat's schematic verbatim. That was how it was shown but there's got to be a grid reference. The AX84 HO power amp uses 1MA to ground in that position with a 5k6 grid resistor. Both the AX84 and Mat's amp are cathode bias. Mat used 120R/220uF where the AX84 is 130R/100uF.10thTx wrote:The grid resistance value going straight into the EL84 is 280k & there isno dropping resistor to ground like you'd see on a Hi-Octane. Correct? (with cathode not fixed bias)
Perhaps Mat will chime in here to clear up the grid issue.
grid reference
Reviewing the schematic, perhaps the Mstr Vol is acting as a grid reference?  However, it would make sense to me to have a fixed resistor to ground in there also?
Thanks for the replies! This is an intriguing amp and I sure like the sound clips that were posted. Very cool tone to it, IMO.
Re: grid reference
On the AX84 schematic, that is definitely the case. The 1MA is acting as the grid reference, just in front of the 5k6 grid resistor.10thTx wrote:Reviewing the schematic, perhaps the Mstr Vol is acting as a grid reference?
I heard back from Mat. The Mini HRM schematic is correct as shown with 180k and 100k in series as the grid resistor for the EL84. He found that this (280k) sounds best. The 1MA Clean Master and 1MA OD Master act as the grid-to-ground reference, depending on which channel is selected of course.
I corrected several typos and housekeeping issues on the schematic and posted the updated version (page 2 of this thread). I removed the optional fixed bias circuit as the output would need to be changed from what Mat had and I do not want to add confusion to what is basically straightforward and already sounds great as is.
				paisley_tele
Re: EL84hrm
can anyone make that into a layout
						Re: grid reference
http://soundclick.com/share?songid=8956976
Strat clip with Kinmans on it. Drive full, PAB on, Midboost on + I upped the internal prevolume trimmer to 1:00 o'clock. Drive master at 12:00. Guitar volume not full on the beginning of the clip. First take. Horrible
mat
						Re: EL84hrm
Man that must be an awesome studio recording amp.
Sounds great!
									Sounds great!
