I think I have my PI balance pot hooked up backwards from TWilcox and mikeywoll. So fully counterclockwise is 0 ohm, fully counter clockwise is 11 k ohm (measured). You can see it on the front panel, with the resistances crudely inked in. EDIT Finally have an amp that goes to 11.mikeywoll wrote: ↑Tue Apr 20, 2021 5:08 amHave you played around any more with the trim pot? I tried setting mine by matching the voltage on my multimeter measured at the grids to the power tubes. They matched voltages at 3.9K. Sounds good, but I haven't had a chance to turn up much since the change. It seems a hair louder at this spot. It was a bit off from where I had set it by ear.T Wilcox wrote: ↑Sun Apr 18, 2021 3:49 amI think it was between 2-4 during that testpullshocks wrote: ↑Sun Apr 18, 2021 2:31 am What volume setting on the amp during your test? I have not turned up past 2
The Ampbooks paraphase calculator indicates a pot setting 4k ohms would be balanced. How does that line up with what you saw with the signal generator?
I will set it to 4K and see what I get . That would be at 40% rotation and I was getting a good balance between low noise floor and good tone there
Mike
When you guys are talking about PI balance pot rotation I would appreciate you indicating what resistance you are talking about. Thanks
I find that as the resistance is increased, the noise increases. I measured the hum SPL on speaker axis directly at the grill cloth as described in an earlier post. With this method, I see a pretty linear increase of 1 dB per k ohm. No dips, nothing funny
With a guitar plugged in, the higher resistance, the louder it gets. It sounds good no matter what the setting, maybe fuller at the highest resistance settings, but that could be the classic psychoacoustic "louder sounds better" effect. The power of this amp limits me to volume settings no higher than 4, and in that range and with Kinman strat pickups, I am not getting any overdrive to speak of, so can't comment on the effect of PI balance setting on overdrive.
I changed the "voice" switch per mikeywoll's post. Much better.
I happened to see the schematic of the Fender 5e9 today, and it has a 12AX7 paraphase PI. The plate resistors and cathode resistor are 220k/1.5k compared to the Monarch's 100k/470 ohm. I plugged these numbers in the Ampbooks paraphase calculator. It gives a value of 3.45k for R2, equivalent to the resistance of the monarch PI balance pot. The value Fender used is more than double that. Food for thought.
Speaking of Ampbooks, found a couple other interesting reads that are relevant
https://www.ampbooks.com/mobile/amp-tec ... -follower/ It gives quite a bit of info about the Fender paraphase PI before going into the more elaborate Ampeg circuit.
https://www.ampbooks.com/mobile/amp-tec ... t-7145392/ It has to do with sonic effect of unbalanced signal to power amp.
 ). That is pretty much where I landed via the dmm method at 3.9K.
 .  Bass player in that video died about a month ago, so it's been rough going lately.
