Any interest in seeing some Dumble Tweed Deluxe photos?
Synchu
Re: Any interest in seeing some Dumble Tweed Deluxe photos?
Post by Synchu »
mhartman wrote:
Synchu wrote: What I find out is that it has even less headroom than the standard 5E3 circuit, I build (granted the standard has 12AY7 at V1, but still I would have expected cleaner amp :/)
With PAF style pickups equipped Gibson it is already in the overdrive territory on 2.
Is that to be expected or am I missing something?
Based on Charlie's description at the beginning of this journey, I think that this might be normal. I'll have mine finished in a day or two. I'll let you know if I find the same.
Thanks, Mike. Appreciated.
That was my reading, but still I thought it will get at least to the "standard" circuit level of clean.
I will do some calculations and LTSpice model should time permits.
Niki
mhartman
Post by mhartman »
Charlie Wilson wrote:Hello,
All of the orange drop caps were the 716 series.
CW
Thanks Charlie!
What did most of you use for the Power Transformer?
Standard Tweed Deluxe specs?
Or blackface values?
Synchu
Post by Synchu »
Tweed Deluxe PT here.
Niki
jelle
Post by jelle »
I used the Classictone 5E3 set.
Jelle
Blackburn
Post by Blackburn »
jelle wrote:I used the Classictone 5E3 set.
Jelle
Same here.
Thanks Gents!
rogb
Post by rogb »
Classictone 5E3 for me too - I used the 40-18078 (I used the 330-0-330 winding) and 40-18090 4-8-16 OT - it really sounds good to me.
jelle
Post by jelle »
Jelle
Sorry my bad, 40-18021 it is.
Is everybody using a 5Y3 or GZ34 with that transformer?
I have my Tweedle D amp completed, doing voltage testing now.
With a JJ 5Y3 and JJ 6V6GT power tubes
V1- GE short plate 12ax7
V2- Sylvania long plate 12ax7
B+1 384v
B+2 346v
B+3 303v
B+4 281v
V1 plates 175/ 177
V2 plates 204/ 250 ( I may have to double check that reading or replace the tube.
I used a 330R 10w cathode resistor initially.
With 24v on the cathode resistor I come up with 13.5w
I will probably do a stack like the original to better dissipate heat.
jelle
Post by jelle »
How does it sound? :D
I tried it with a Strat with a bridge humbucker and it sounded pretty good.
My voltages are within range of the Dumble amp ~5-10v lower
With the 330R cathode bias resistor I came up with 26 watts or 13.1w per tube.
Is that a problem?
How much current are you guys running on the cathode?
I am using the JJ 6V6's
roknroll
Lack of videos and clips
Post by roknroll »
I know I am a bit late in the conversation but the excitement level here has me baffled and intrigued. There are no clips that I have found or videos any where. What gives? :? :?
