New HRM build
ic-racer
Re: New HRM build
Post by ic-racer »
I spent about a year remodeling my music area. So I hadn't played this amp for quite some time. This is a recent recording of the amp. The amp sounded pretty gritty compared to my #124 and I wanted to record it with all that coarseness and grittyness. The clip gets good at the end when I plug into the FET input.
Re: New HRM build
ic-racer wrote:( *** sound recording clip here *** )
Sounds...transparent?
ic-racer
Re: New HRM build
Post by ic-racer »
Problem with the upload and recording.
Here is the link. This thing rocks!
https://www.youtube.com/watch?v=E3mdRtkfdhI
stelligan
Re: New HRM build
Post by stelligan »
Yup. RAWKS! :)
groovtubin
HRM
Post by groovtubin »
would love to jam with you here at church! My HRM is a serious hi gain affair!
lovetone
Re: New HRM build
Post by lovetone »
Wow what a tone, is there a schematic of your build? and which amp did you base your build off?
Cheers
ic-racer
Re: New HRM build
Post by ic-racer »
lovetone wrote:Wow what a tone, is there a schematic of your build? and which amp did you base your build off?
Cheers
Thanks for chiming in. Just so you don't have to read through all the pages. As far as I know it is very close, if not exactly a "real" schematic based on an amp 200 to 250 serial number and the schematic is posted earlier in the thread.
I got confidential info from various sources on this build and all info I know is included in this thread, however, I have not indicated what is known and what is unknown to protect that information.
There were posts about the HRM trimmers earlier but this is how they were set for the recent video:
Treble: to treble cut slightly
Mid: to middle on the dial
Bass: to 32k ohm
Note: I was testing my EL34 Marshall amp and realized that for my cabinet, playing style and guitar it sounds best with the tone controls in the middle. So I wanted to try setting my HRM trimmers to the middle with some treble cut.
The Treble and Mid are linear in both Marshall and HRM, but the Bass is log taper in the Marshall. So the question was, "where is the 'middle' of the Bass trimmer on the HRM?" On a log scale the half-way point between zero and 1000 is about 32.
The pictures of the original show the FET trimmer glued to "max on" and the OD trimmer glued to just 11:00.
When I set my amp to that configuration, and plug into the FET input, the OD DRIVE knob on the front of the amp is beautifully balanced with "12:00" giving the tones used in the last video clip. Cranking the knob goes into extreme OD and backing off gives a fantastic Larry Carlton dynamic sustain.
BTW I set the PI trimmer on clean by listening for the best ringing 'bell tone' on the open e-string.
lovetone
Re: New HRM build
Post by lovetone »
Thanks for the into
I have built one HRM amp using the same schematic and the schematic 101 HRM it was a very nice sounding amp.
To set the HRM tone stack I got best results using a scope.
The amp was setup so that the PAB was engaged at the same time as OD I then using 1K signal I adjusted the HRM tone stack until the trace resembled that of a standard ODS amp.
Hey Presto it had perfect OD tone, i remember that the bass pot was only just on and that it effected the mid and treble depending where you set it.
The problem i had was that the OD output was quite compared to the clean other than that it has great tone.
Cheers
ic-racer
Re: New HRM build
Post by ic-racer »
I'm continuing to explore this amp with my new recording setup.
Here is a jam along with Robben's Blue line. Robben is mixed in the background. Main amp in the audio track is this HRM. Robben is probably playing #102 in the background. Much different sound.
https://www.youtube.com/watch?v=lA2cPye9P0U
ic-racer
Re: New HRM build
Post by ic-racer »
This is a track I did with this amp a while back. Guitar is a Stratocaster.
https://youtu.be/3fA1YYqq7FY
sepulchre
Re: New HRM build
Post by sepulchre »
Nice! Very smooth and lots of depth.
bnwitt
Confidential Info?
Post by bnwitt »
I will never understand the reason for confidential info in a clone amp building forum. Anyone who thinks information should be kept confidential can only believe so based on three reasons:
1. out of respect for the original designer (which is BS if you are building your own clone as that is not respectful) or
2. because they think they can make more money building and selling clones if secrets are kept.
3. if posted said secrets what cause a lawsuit to be filed against the forum
I mean seriously, we all know that the way to make a million dollars building amps is to start with two million. So having dispelled two out of the three reasons, is HAD prone to suing over clones? A clone is no where near a HAD built amp in our wildest dreams. So what is the reason in here?
Great things happen in a vacuum
ic-racer
Re: New HRM build
Post by ic-racer »
4.) Trust
Forums are interactions between human beings. Many laudable interpersonal relationships have trust as a foundation.
bnwitt
What?
Post by bnwitt »
ic-racer wrote:4.) Trust
Of course I understand if someone asks you not to share you are trusted and don't share. My post is regarding why someone asks you not to share in the first place.
Re: New HRM build
The problem stemmed from a certain amp company in Malaysia that used data from this site to build much of their product line.
I think what was hurtful was that the man never acknowledged this forum or any other credit to individuals that provided information.
Also customers of said amp company would come here for tech support, rather than the forum provided by the manufacturer.
It's just a little niggle. :wink:
