Eric,
My layout is my own and not really like a real Rocket so my layout would probably just cause confusion.  But I'll post pics soon.  I still haven't received my faceplate and I was hoping to at least have that installed before I post pics.  But gutshots are the same either way.
And FWIW, crunching my numbers from above (restated here):
Plates = 303vdc
Cathodes = 9.5vdc
Screen supply = 300vdc
Some screens were 296 some were 297, so I'll take 296.5 as an average
Shared cathode resistor = 50ohm
Seperate screen grid resistors = 470ohm
300vdc - 296.5vdc = 3.5vdc
3.5v / 470ohm = .00745 A or 7.45mA per screen
296.5v - 9.5v = 287v
.00745 * 287 = 2.14W per screen
9.5v / 50ohm = .19A = 190mA
190mA / 4 = 47.5mA
47.5mA - 7.45mA = 40.05mA
303v - 9.5v = 293.5v
40.05 * 293.5 = 11.75W per plate
All seem reasonable.  Even though I'm using 470ohm screen grid resistors the screens are slightly over the max dissipation (data sheet says 2W) but the plates are slightly under the max dissipation (data sheet says 12W).  This is not a matched set BTW...all I had on hand.  Will be curious to see what the numbers are for a 'stock' arrangement.
Is this work day over yet?!?!?
