uTracer (Micro Curve Tracer)
MakerDP
Re: uTracer (Micro Curve Tracer)
Post by MakerDP »
Here's a place to start looking...
https://www.mouser.com/Search/Refine?N=19978893
dorrisant
Post by dorrisant »
M Fowler wrote: Tue Sep 10, 2019 2:34 pm Martin and others thanks for all the information you guys are providing. I bought a kit last year and waiting for cold winter and quiet times to get started on mine.
The only parts I need are those ferrite beads where did you get yours? I guess I need to know what size wire I will be using first.
If you are looking for the through-hole type that look like diodes, PM me and I'll send you however many you need.
M Fowler wrote: Tue Sep 10, 2019 2:34 pmThe only parts I need are those ferrite beads where did you get yours?
Mouser 710-74270015 10mm long 4mm OD. I used 22 AWG wire with thin insulation for the sockets. The usual 22AWG 600V PVC insulated wire won't fit through these ferrites.
Thanks guys. Tony I'll get ahold of you. Thanks
markusw
Re: Distortion Analysis
Post by markusw »
martin manning wrote: Mon Sep 02, 2019 7:03 pm Wow, 18 months since I've updated this thread. My uTracer has been down for some while due to a computer upgrade, which required a new memory partition (MacBook running Bootcamp), a new copy of Windows 10, and a new FTDI USB-TTL cable (the old one was obsoleted by the new Windows 10).
I'm planning to build a uTracer and like your apporach to use a FTDI USB-TTL cable.
Which cable did you end up with that worked with Win 10?
BTW, thanks a lot for sharing all your observations! It is always a pleasure to read your postings!
Best regards,
Markus
dorrisant
Post by dorrisant »
Martin, how many of the ferrite cores should you need for one tracer?
Mark, what I have on hand is not what is referred to in the context. I will order a bunch and send you some.
markusw wrote: Mon Sep 16, 2019 11:52 amI'm planning to build a uTracer and like your apporach to use a FTDI USB-TTL cable. Which cable did you end up with that worked with Win 10?
TTL-234R-5V-AJ. I like the TRS plug.
Edit: TTL-234X-5V-AJ
Last edited by martin manning on Sat Sep 21, 2019 1:47 pm, edited 1 time in total.
dorrisant wrote: Mon Sep 16, 2019 2:40 pm Martin, how many of the ferrite cores should you need for one tracer?
Depends upon how many sockets you have. I put one at each pin on each of three sockets, 7, 8, and 9-pin, so 24 total.
markusw
Post by markusw »
martin manning wrote: Mon Sep 16, 2019 3:26 pm
Thanks a lot! I like the TRS plug too! :-)
Best regards,
Markus
markusw
Post by markusw »
I can't find a TTL-234R-5V-AJ cable, only TTL-232R-5V-AJ.
Do you have a link?
Thanks again!
Best regards,
Markus
My apologies, TTL-234X-5V-AJ is the one I am using now, and it is available from Digi-Key: https://www.digikey.com/product-detail/ ... ND/6823720
The 232R is the first one I used (originally with Windows 8). It worked with my Windows 10 upgrade, but as far as I can tell it is not supported for new Windows 10 installations.
markusw
Post by markusw »
martin manning wrote: Tue Sep 17, 2019 10:06 am My apologies, TTL-234X-5V-AJ is the one I am using now, and it is available from Digi-Key: https://www.digikey.com/product-detail/ ... ND/6823720
The 232R is the first one I used (with Windows 8). It worked with my Windows 10 upgrade, but as far as I can tell it is not supported for new Windows 10 installations.
Thanks a lot, Martin! :)
Best regards,
Markus
Ronald’s “Grid Loupe” is up and working. This add-on circuit solves the problem of getting to true 0V Vg, and enables tracing curves with up to +5V on the grid. In addition, the screen current measuring circuit can be used to measure grid current for triodes.
Basically, the Loupe creates a regulated 12VDC supply, isolated via a DC-DC converter (the black box on the board), which is then stacked on top of the 20V main power supply (to which the cathode is referenced). The loupe then has 32V to work with, -20 to +12 with respect to the cathode. To set the grid bias, the existing grid circuit control voltage is tapped and fed into a pair of op amps that convert it’s 0-5V into -10V to +5V, with some current sinking capability. Two more op amps and a transistor create a current equal to the grid current, as determined by a 10 ohm current sensing resistor, and that can in turn be fed into the screen current measuring circuit.
The plot shows 12AX7 anode curves for Vg = -4 to +1.5V, and the me.asured grid current, which does not increase significantly until the grid voltage goes above 0V. There is an offset of about 300 uA in the indicated grid current that does not look correct, though. I'll have to look into that.
It looks like it will be possible to mount this little board inside the enclosure, and add a 3-way switch on the panel to select the normal grid bias circuit, the low-Vg loupe, or the same with Ig measured by the screen circuit.
A new 3-way switch has now been added to the panel to select normal, low/positive Vg, and same with Ig measured using the screen circuit. The availability of positive grid voltage opens the way for tracing more transistor types, too. The low-Vg board is mounted with two layers of foam tape for now; a technique I’ve been using for pedal circuit boards. It's getting very crowded in the box!
You the man Martin, very nice thanks for keeping us up to date.
