Hi,hitchcaster wrote:i tried the texas instruments version, i think it was, of those resisters.. got them direct so not as much $... but they suck for everything ive tried them in that was guitar and amp related... they have a unique sound, but i guess its only good for hifi because they always sound worse then anything else basically.... id look elsewherediagrammatiks wrote:Have you used any of the z-foil resistors?renshen1957 wrote: Hi,
I've used them primarily as cathode resistors, and in a few places where I couldn't get the values I required by other brands.
I've read of another hi-end brand with internal breakage, the leads bent to close to the resistors body, the older Holco brand.
At $0.45 a piece 1/2 watt, these are inexpensive made in the USA metal film resistors. I never have the problem, but I use two forceps to bend leads.
Since I use some resistors that start at $3.50 and higher for 1/2 watt and 2 Watt at $15.00 and Vishay VAR-Series "naked" Z201 Z-FOIL RESISTOR 1% 0.4W start around $15.00, I don't consider 45 cents all that expensive.
Needless to say I don't use these Hi price for every resistor position.
The green Vishay Sprague/Kiwame 2W Carbon Film resistors make a nice color contrast to the PRP. Not that the electrons care what color resistor they flow through.
Best regards,
Steve
I agree about the Z foils, only place to use them would be V1a position, and frankly other less expensive conventional Hi Fi metal films sound better. You can get a little warmth with Tantalum Films, but the Kiwame and AmTrans Carbon Film would be cheaper and Takman's Rex are good, too and a pretty colour for all us who want eye candy in our Amp.
TDK makes 2 watt Metal Film resistors http://www.partsconnexion.com/resistors ... _watt.html
As to price, $0.11 cent resistor in 1960's would cost about $0.80 cents. So the price for non-magnetic resistors isn't that expensive. I use a magnetic to check resistors, if its very magnetic, good chance that it is cheaply made (regardless of cost). Slight magnetic attraction isn't necessarily bad, as this usually is associated with higher voltage rating.
Best Regards
Steve
