JTM45 problem
flatart
Re: JTM45 problem
Post by flatart »
I put 5.6K resistor grid stoppers and the problem is completely solved!!!
Anyway I really dont understand why I've been using this amp for one year without grid-stoppers and suddenly I need them: it's a mystery....
Thanks everybody for your precious help
Re: JTM45 problem
:wink:
jelle
Re: JTM45 problem
Post by jelle »
Tubes can get microphonic as they age.
Re: JTM45 problem
So exactly what are we hearing in the clip?
Given the assumed purpose of these resistors would the distinctive ripping sound be a breaking into and out of a parasitic oscillation that is triggered when the signal amplitude is high? And, why did it not occur previously? Do the inter-electrode capacitances change as the tube ages? Presumably it is some electrical characteristic that has changed over time, since altering only the electrical characteristics of the surrounding circuit cured it. Flatart, did you try a different set of tubes an any point?
MPM
Re: JTM45 problem
It could have even been an existing bad solder joint that was addressed when he changed the grid stoppers.
Re: JTM45 problem
Structo wrote:It could have even been an existing bad solder joint that was addressed when he changed the grid stoppers.
Apparently not:
flatart wrote:I re-soldered almost all the circuit: output tubes pins, all bias circuit, all pots and all solderings that may appear not so good, but nothing changes.
So next try I will put a grid stopper on pins 5 (I will go for 5k resistors).
I will also try to disconnect feedback (never tried yet).
Another strange thing I noticed is that also when I put scope-probe on pins 1 and 6 of PI the problem seems to disappear or at least is quite quite less evident.
The effect of the scope probe, essentially inserting a high value resistance to ground, is interesting too.
MPM
flatart
Re: JTM45 problem
Post by flatart »
Really I did reflow all solders but I still had the problem.
As I said in previous topic I also tried a couple of 6L6GC but nothing changed.
The only thing that fixed the problem immediately was grid stopper resistors. I mind that I tried it at last, but at least now all solders are almost perfect!
flatart
Re: JTM45 problem
Post by flatart »
sorry, forgot to say that I tried also to change all tubes in the circuit, one at a time
karmakim
Re: JTM45 problem
Post by karmakim »
Your Plate wire is too close to grid wire near your powertubes. Try to move the wires..
..And then you can remove the grid stoppers..
